Elec help - no dash lights, no cruise control, no power to ODB etc…..
- Replies 8
- Views 2.7k
Mopar1973Man 2 posts
JAG1 1 post
Haggar 1 post
Tractorman 1 post
Popular Days
As @JAG1mentions, a ground could be the problem. It wouldn't hurt to recheck the wire connections - sometimes a terminal can be pushed back into to the connector and not make contact when the connect
according to the earlier schematic, it is the Junction Block, but interior fuse panel seems good too. Hag
Hello,
I’ve got a 2001 3/4 ton 4wd auto quad cab diesel. About a week ago I changed the lower and upper dash, heater core and clock spring. My problems are the following items are not powering up. Cruise control light will not come on, no lights in dash or cluster, (all gauges in instrument cluster work, odometer and trip meter work) ODB connector no power, dome lights not working (though they could’ve been out before the dash change). I’ve checked fuses for continuity in the fuse box in the dash. I haven’t checked to see if they have power. I’ve gone over all of the connections that i disturbed during the dash replacement. The three connections on the back of the fuse box are the question mark in my head. I’ve checked them - and they are all plugged in. I’m wondering what would happen if i had plugged them into the wrong spot? They are very difficult to get at when the dash is in. When you remove the dash and it rotates down, you have better access through the back of the dash. But - as far as i know they are connected in the right order. Does anyone know the order by color? They are brown white and blue if I remember correctly. And that’s listed from the top down.
One other related item. Chime does not work when the lights are on and the key is removed. Chime does not work when the door is left open with the key in the ignition. Chime does work for indications on the instrument cluster. My windshield wiper fluid bottle is empty. It let’s me know this every time I start the truck. So that part is working like it’s supposed to:)
Horn works, turn signals work, all exterior lights work like there supposed to. Clock spring was changed due to airbag light coming on anytime i turned the wheel. (I temp installed another one to see if it was the culprit for the cruise control - no joy)
BTW. No codes when the key is rotated three times. Can’t use the ODB port due to no power.
Can someone point me in the right direction please. I’m guessing that all of the items that are not powered are related to one item.
Thanks,
Steve
