Random charging and not charging.
- Replies 12
- Views 3k
Mopar1973Man 7 posts
JAG1 1 post
015point9 1 post
Silverwolf2691 1 post
Popular Days
Well be careful starting so early
So after lunch I went out and started it up and no charging. I remember the error code for the ASD relay so I swapped with the ASD relay it started charging. Weird. Drove 30 miles to Riggi
The best I can say in the ASD relay either had bad contacts inside or the plug in the PDC was a bit corroded from moisture and standing a while. I'm going to be working on getting the pine pitch of th
I been working on The Beast to get it running once again. So far every time I offer to take Eileen anywhere for dinner the truck stopped charging. No joke. Then come back the next day fire it up and runs and charges fine. I drove up the highway to to friends places to show off the truck a bit and give aid with projects. Then Sunday night tried a repeat. Eileen comes to jump in and just as I leave the driveway the check gauges pops back on and charging stopped again. I did run the codes off the odometer really quick last night.
P1682 and P1389 if I remember correctly.
P1682 is low charging voltage
P1389 is a ASD relay no power seen from PCM. (Bad ASD relay?)
