Low boost, no boost leaks
- Replies 20
- Views 4.2k
dieselautopower 5 posts
Silverwolf2691 5 posts
Ravewolf 5 posts
Threadzy 2 posts
So I recently got back into messing with my truck, and I've been messing with quad. Starting logging what my truck was doing with "hot" tunes, noticed I wasn't building boost beyond 18psi. It would build up to 18, then drop to 14-15psi.
I suspected boost leak, so I made a janky boost leak tester (which failed epically), and found a tiny leak on the right side boot going into the inter-cooler. My former diesel professor suggested I use a smoke machine to check for leaks, which I did, and didn't find anything. I went ahead and ordered a cheap set of silicone boots for my truck anyway. I reused my old t-clamps, and although they were a huge pita to put on, I got them on, and got the clamps tight. Loaded a hot tune, and went for a ride.
So far, I can hold boost at 18, but it won't go beyond that, because my fuel cuts off (I'm set at 3700rpm cutoff). I suspect it's the adapter for the outlet of the turbo, but I have it tight using the v-band clamp it came with, and the o-ring looked okay, not flat or anything like that. It also never leaked when I used the smoke machine before, and I made extra sure I had it seated flat before I clamped it.
At this point, I'm at a loss as to why I can't build boost with this turbo, unless the vane's are junk. Or does it need more fuel? I'll post the log.
iQuad-2021-10-09-05.51.061630790263729018886.csv
