Post Mod Trans Issue
- Replies 37
- Views 6.2k
Andyba20 11 posts
Mopar1973Man 8 posts
JAG1 6 posts
Turbo Terry 3 posts
This is true. The Government will always need a supply of petroleum jelly, IE: Vaseline, to help ease the pain when they're sticking it to you. This is your Government caring for you.
Governor pressure sensor and solenoid Sound like to me. I wouldnt drive it very far in this condition if it’s smelling burnt. Up on a flatbed to the shop or you might be buying a new tranny
Hmm. Upgraded governor support? No governor in 47re. Sonnax valve body with transgo recall kit? The sonnex is already an improved valve body. Why both? The diesel tranny already has the heavy duty pla
This morning my truck wouldn’t shift into 4th gear without letting off the throttle, actually got worse as the truck got warmer. Then, it almost stalled at a red light, and I realized it hadn’t downshifted to 1st. Checked the trans oil (less than 3,000 miles) and it’s good and dark red, but smells burnt. Wanted to get a good list from the forum of things to check before I send it to a shop. This is 3 weeks post WT mod, which IMHO has been the single best mod I’ve done to the truck. No codes. I’m going to reset the TIMBO apps.
