Will 5th gen wheels fit your 2nd gen Ram?
- Replies 22
- Views 20.6k
Sycostang67 6 posts
Mopar1973Man 5 posts
Dieselfuture 5 posts
SilverMoose 2 posts
Got my 3rd gen wheels mounted with some new rubber so it's back to stock now. Got my spare tire updated as well since it had more cracks than a plumbers convention.
I just got some OEM Dorman lugnuts. Part number is 611-162, cost about $3 each, luckily you only need one, I needed 32.
Pitch meaning thread pitch. It must have changed in 2010?? They do use the same lug nut cone angle.
Yes, they will. I picked up this set of 2021 wheels the other day with new 245/70R17 Firestones. The guy gave me the lug nuts but Dodge changed the threads at some point so I am using my old spiked nuts for now. I didn't realize how tall these lug nuts were until I put them on these wheels. This was a test to see if how well a smaller tire will work like Mike has. So far my cruising EGT's are down about 150-200 degrees. I'll have to do some more driving later to verify. I was able to pull flat out run on level 4 up to 85mph and not exceed 1200* and that's with a tune I'm messing with so all bets are off, lol. I'll roll with these for a little bit while playing with the Quad, if I am satisfied I'll either have these tires swapped onto my Raceline wheels or get another set of the 5 spoke 3rd gen wheels.
