Angry & can't do it anymore, serious iQuad timing issues
So for how ever long I've had my back to going normally, I cannot get my timing and everything thing else figured out. I been talking, chatting with @Mopar1973Man for quite a bit over the past month plus and give him all the credit for getting me thus far, however I figured asking additional input wouldnt hurt.
My egt's are through the roof! 800-900* cruising 65 mph. Slight hill or Itty bitty incline 1100*. Lord help me if I wanna pass or just even getting up to speed 1500*
Oil and coolant always the same 195* give or take. Oil should be cooler. Engine load now seems to be 19-20 going 65 mph.
I think this is what I was running yesterday and this morning. I have tweaked it a bit since so...
I believe timing was 14,18,22,25,26 or some where close lol, it's been all-over the place lately; it doesn't matter it's all wrong and I'm just to dumb to fix this. Please be gentle....
20220328_062907.jpg.6feb17950491c2ffca5729ab6ee4d184.jpg20220328_063245.jpg.03460d265000fef0823d1740d5ac4565.jpg20220328_063904.jpg.265f34a3f4f0074485fffa5f5840ecb1.jpg20220328_063855.jpg.38ca2cf540cf55fdb17d4f4bc4d0c761.jpg
I seriously need all the help I can get. I'm losing my mind. I want a nice daily that has a little pep than stock, just to start. I can't get there... sig is up to date, (new IJ pump not tapped), turbo and injectors billing the big contributing factors here. I will admit that I will have to compromise something for something and big injectors don't usually help egts and mpg but come on 900-1500* and 11 mpg ??? What gives?
Oh and I really don't get any black smoke for what it is **testing purposes only**
That will later become a inevitable side effect when a race tune is born.
Idea i had.....I'd be open to doing a screen share with iQuad while driving...
  • Replies 180
  • Views 28.4k
  • DAP lists 6x.013 injectors as "325 HP". (325+235)/235 = 2.38.  Your injectors supposedly inject 2.38 times as much fuel as injectors normally used with that SO injection pump.   The rec
  • The way it works is from idle state aka tps = 0 to 1200 rpm there is a handoff happening that is more complex than a switch on or off.     how it works If you apply the throttle be
  • The "Dave Ramsey" and "old grumpy dad" in me says to instead buy some 150s from DAP and source either a stock HX35 or that HE351W I shared before. Would HAVE to be way less money and you could use tha
I understand the Adrenaline doesn't do much, if anything, under 1,500 RPM (or thereabouts), but does it adjust CANbus fueling at lower engine speed? Just an ignorant question since we're on the topic.
Actually its 1,200 RPM is the breaking point where the Quadzilla hands back off to the ECM. At that point the ECM is back in control so as long as the RPMs are above 1,200 RPMs then the Quadzilla is still handling both timing and fuel management.
Oh, that's great! Not sure why I thought it was 1,500.
That was one of my hang up cruising 30 MPH through Council, ID every morning hit 30 MPH in 4th gear and it would buck horridly being it was right at the 1,200 realm and also if the 1,500 band was 14 or 15 degrees is would buck really bad. Now it very slight at 13 degrees. But still feel the 1,200 point where the timing retards (ECM control). This why I suggest 13 degrees for the manual transmission where on a Auto they don't di low like that so you can run 15 degree on the 1,500 band.
how it works
If you apply the throttle beyond %2 then the quad takes over control if rpms are greater than 1000 .  from that point the quad is told to fuel, until either rpms fall below 600 or tps goes back to 0.   and the limit for the quad is turned back to 1000 rpm for the fueling take over.
If speed is greater than 30 mph and rpms are greater than 1200 then the quadzilla is in control regardless of tps, I dont remember why this is the case, but it was required during testing
the issue with manual trucks having bucking at extremely low RPMS I believe is a function of the ecm sending high priority messages for anti stall functions when it thinks the engine is at rise of stalling.
Remember that there are 1 forms of communication between the ecm and vp44, 1 is standard priority commands 2. high priority commands.  Tuners use method 2, but the ecm only uses #2 method sometimes to prevent what it see's as issues.      If the ecm thinks there is an issue, such as stalling it will send a high priority command which will conflict with the tuners fueling ressulting in odd behavior.
Same is true for fueling beyond ~3750 rpm.  The ecm see's that as a runaway condition and effectively sends high priority commands of 0 for a fueling command then locks the outputs from the ecm on the j1939 bus if the vp does stop fueling.  This is why we had issues with the quad freezing when we tried to hold canbus fueling beyond 3800 rpm.
I'm still not a fan of a linear ramp up of full from defuel state right up to max fuel. This is not a efficient fuel ramp because you always will seem to be ramped up power mode which typically does end up adding more fuel constantly might be slightly but it is.  Best for economy purpose you need a defuel zone for building boost and controlling smoke. Then the realm where the truck normally cruises at highway speeds should be at 100% stock fuel for economy purpose. Then above that cruise zone you can ramp up linear to 150%. This way your more or less floating on the stock ECM fuel map but when power is needed then it ramps up.
  __________________/
I know this isn't to scale. But basically that  what the fuel table should be for economy purpose. Remember don't try to build a performance tune in a economy tune it WILL NOT work. Now on a performance tune yes you would want to ramp up as fast as possible. This why Quadzilla is a great tuner you can build as many tunes as possible to fit every thing you may do with your truck.
That whole post you made is fantastic for helping us mere mortals learn a little more about how these operate.
@Mopar1973Man I think it would be beneficial to have a folder somewhere on this site where we can cut and paste these kernels of knowledge that show up in random, otherwise barely related posts. Maybe it could start as a sticky thread where we members can copy and paste these tidbits, then at some point one of us can take them, clean them up, and make an article of sorts? I just don't know how to do all of this on a webpage.  I can dig around and find some posts I remember were helpful and copy them into a Word file, if that is helpful.
Great stuff here!
Yea PO said he pulled some with it, don't know class, but it is what it is at this point. So I didn't start working with the most street friendly stuff, now it's alot better from what I had, so on the bright side there's progress...
Don't hate me for this but right now it's just a daily driver, didn't expect 20mpg or anything crazy, just something better than 6x18 and DF pump churnin ponies... So basically Id like a decently fun daily driver, don't think I'll get any better than that out of 6x13's... I may randomly tow here and there, kinda rare, but things can change, so tow tune can come later. If could get 15mpg that would be a huge jump, and cruise 600* egt would be a nice. Any better than that--icing on the cake!
I'll try this fuel curve now about to head home.
I agree with @LorenS little tidbits like he mentioned would be great to keep on hand.
 so 6 x .013's flow a ton of fuel, more than a vp can.   so goals and a desired hp level would be good.   twins would by my suggestion for a towing 600 hp setup, however you 64 is not really geared to that.
a play truck with 6 x .013's can still work, but that 64 is a 2k spooling turbo on a 4.10 manual truck.  it's not a 1400-1500 spooling turbo.
what speed do you want to cruise at?
Maybe the Quadzilla should take over all RPM and be the idle governor instead of the ecu it would have to fudge some of the reply messages from VP to ECU to keep it happy.  IDK that could be pretty tricky.
Yes I knew they where big, just thought it was a better option than 6x18 haha...
I guess I need to start figuring out/learning twins?!?!
Daily play truck:hyper:? I can live with it!
2k is indeed the area where it hits.
However, I'm only hitting boost in the 30-40 psi range right now... not enough fuel yet??
Edit: I reference (only 30-40) just due to what I used to get with it. It could peg a 60 psi gauge...
I think 70 mph is a good number for hwy cruise. In my wife's car it's 75 for all the interstate driving lol. I currently have only been driving/testing @ 65mph for all this. I'd rather 75 :lmao:but let's face its got 4.10's....
Edited by Stanley
if you want to drive 75 then 3.55's are needed and mpg is not gonna be great.    the turbo is really a hit at 2k turbo so if that is not what you are after i would be talking to @dieselautopower about a better turbo that can be paired with a s475 down the road in a twin setup.  I would think a 62 sxe would be a night and day difference, I am not sure how well the 57 gxe's wastegate works and if you could do a 57 with a a s472 or something, that would spool like crazy.   but sizing turbos is not my arena.
how was it with the more aggressive fueling curve?
35" tires and 4.10 can be decent for faster highway speeds.
62/68/12 would certainly spool faster.  It works well with an s475 with 96/1.15AR, or s475,83/1.25 or s472/87/1.10 (custom)
57mm GXE is a a better option for twins going for 650HP as it will spool faster.
Did you do any headwork or cam to improve flow?  Tunnel ram?  If you can improve spool up a little it would be nice.  A custom cut 12cm turbine housing would decrease spool time a little.  an sxe 64/68/14 would add more air and make spooling better as the wheel is significantly lighter.
It seemed fine to me, like I was saying the boost numbers seem low to me, smidge of smoke through 3rd and 4th, not clouding out the intersection though.
I think the obvious hindrance is the turbo spool down low, cause it's laggy up untiiiiiiillllllllll 2,000 rpm lol
Engine supposedly has a Hamilton cam, can't 100% confirm but I assume it's there. Got a BD intake horn, and no grid heater going into the plenum
Yall got me really wanting to throw some money at 2 turbos right now... That's gonna be expensive!!
Anyone want a 64/71/14 ?🤣 (Wastegate works ust can't hook it up on mine)
The "Dave Ramsey" and "old grumpy dad" in me says to instead buy some 150s from DAP and source either a stock HX35 or that HE351W I shared before. Would HAVE to be way less money and you could use that until you have a pile of money for the 2-turbo setup. With that setup you could follow Mike's setup almost exactly. Sell your current turbo and keep the injectors.
I figure someone should throw out the stick-in-the-mud advice, can't believe it's me!
Edited by LorenS
On 3/29/2022 at 9:18 PM, Stanley said:
I was totally on the same track as you this morning, however this afternoon Im thinking otherwise. Isn't 70% the lowest canbus setting; Or the lowest usable percentage?
Think again. 2001 HO, HRBDVP 44. 6X13 Infinite, 93 drilled out fuel tubes, stock lines though. & a S468 single. I dare anyone on this forum to think they could leave me on the line. Quite the opposite as all you would see is tailgate.
Here is my fueling curve. Try it.006.jpg.b273a42e9afdd3f65b76b5181bf93f0f.jpg007.jpg.e2835f18c4578ffd4d23c9cfa0a68758.jpg
@jag, 13, 14, 15 psi are odd compared to normal thinking.. is there a reason for that?
is your timing still at 16, 18, 20, 22, 25 or something close to that with no push or pulls from cruise and what not?
14 psi should be 81, not 87. Strange it showed that in the picture.
Timing perimeters are 0.0 - 0.0 - 100% - 0.0 - 35%
RPM Max. 16.0 - 20.0 - 23.0 - 26.0 - 28.0
Edited by jag
Double info.
