Angry & can't do it anymore, serious iQuad timing issues
- Replies 180
- Views 27k
Stanley 72 posts
Me78569 30 posts
Mopar1973Man 25 posts
Silverwolf2691 17 posts
DAP lists 6x.013 injectors as "325 HP". (325+235)/235 = 2.38. Your injectors supposedly inject 2.38 times as much fuel as injectors normally used with that SO injection pump. The rec
The way it works is from idle state aka tps = 0 to 1200 rpm there is a handoff happening that is more complex than a switch on or off. how it works If you apply the throttle be
The "Dave Ramsey" and "old grumpy dad" in me says to instead buy some 150s from DAP and source either a stock HX35 or that HE351W I shared before. Would HAVE to be way less money and you could use tha
So for how ever long I've had my back to going normally, I cannot get my timing and everything thing else figured out. I been talking, chatting with @Mopar1973Man for quite a bit over the past month plus and give him all the credit for getting me thus far, however I figured asking additional input wouldnt hurt.
My egt's are through the roof! 800-900* cruising 65 mph. Slight hill or Itty bitty incline 1100*. Lord help me if I wanna pass or just even getting up to speed 1500*
Oil and coolant always the same 195* give or take. Oil should be cooler. Engine load now seems to be 19-20 going 65 mph.
I think this is what I was running yesterday and this morning. I have tweaked it a bit since so...
I believe timing was 14,18,22,25,26 or some where close lol, it's been all-over the place lately; it doesn't matter it's all wrong and I'm just to dumb to fix this. Please be gentle....
I seriously need all the help I can get. I'm losing my mind. I want a nice daily that has a little pep than stock, just to start. I can't get there... sig is up to date, (new IJ pump not tapped), turbo and injectors billing the big contributing factors here. I will admit that I will have to compromise something for something and big injectors don't usually help egts and mpg but come on 900-1500* and 11 mpg ??? What gives?
Oh and I really don't get any black smoke for what it is **testing purposes only**
That will later become a inevitable side effect when a race tune is born.
Idea i had.....I'd be open to doing a screen share with iQuad while driving...
