- Replies 19
- Views 4k
Mopar1973Man 4 posts
jag 4 posts
hdpwipmonkey 3 posts
LorenS 2 posts
Correct, bolt on. They just don't prevent wheel hop, they plant you backside to the road. Once set right, the plant & pull is rathe quite easy to notice. Bars are to be kept straight. out of adjus
My solution to this is to own a truck that doesn't have enough power to spin the tires
They are called Caltracs. No wrap, just *** to pavement.
Hey all. So was cruising down a dirt road here at about 30-40 and gave her some fuel and tires broke loose a bit. With that, I got a bouncing vibration in the rear end and I’m assuming it was axle wrap. Is this normal since I have higher HP than stock with no trac bars? It does the same if I break lose on pavement too. I’m trying to figure out if it’s just the added HP or if something is worn and needs replacing.
