- Replies 36
- Views 5.5k
Doubletrouble 11 posts
wil440 9 posts
Mopar1973Man 7 posts
Max Tune 5 posts
I would like to reinforce the fact that the line you fellas are promoting is a copper/nickel alloy. Wouldn’t want someone to make brake lines with regular copper tubing.
Yes, especially with the hydro-boost brakes. I would think line pressure may be more than your average vehicle. Got it all bottoned up. No leaks. Test drive and stopped very well even a few hard
A few years ago a was on the way to the MOT check with my 3500, engine has to be hot and brakes warm so being the MOT station is only 4 miles away from me I'm stomping it on both pedals, right at the
So I was on my way to work this morning, went to stop for a red light, traffic in front of me when the brake pedal suddenly went to the floor! I knew I blew a brake line at that point. Had to dive into a gas station parking Lot at 30mph to avoid hitting anyone! Downshifting, thankfully I have a manual Trans!
Got her stopped and checked things out best I could. The line that goes into the rubber flex at the right front wheel was soaked. There's the problem.
I'll get under it in a bit to see if it was the flex line or the hard line but either way scared the crap out of me. Day off work now to tend to it. Ugh.
