- Replies 15
- Views 1.4k
Stanley 5 posts
Tractorman 3 posts
Mopar1973Man 2 posts
LorenS 2 posts
Popular Days
If I remember correctly, it's ball, spring, washer(s), fitting. I couldn't find an exact fit washer on hand, had washers that a pencil would fit through and ground down the outer edge to fit. Moparman
That's one of those tips to put in the tip section we were talking about I think it was @LorenS that mentioned it.
Overflow valve operation has little effect on lift pump operation. In the bump start mode the lift pump output flow is basically deadheaded against a non-rotating vane pump in the VP44. This is why
Thought I'd make another little one for this.
Doing some diag and upkeep and stuff from other thread this weekend and came across this...
So I can turn key on, visually see needle on gauge move 0-5 psi, next do a key bump and it shows nothing, no matter how any times I try key bump. I removed fuel line from vp44 and into a bucket. Performed key bump again, fuel flows out great fills up a gallon pail and then some.
When truck is started gauge shows 15psi even while driving.
I also have a spring kit from FASS to increase pressure just a tad. However I have never seen more than 16psi, only sits at 15. Idk why that is??? Stock is around 15, I was hoping for 17 ish...
New vp44 came with a new overflow valve, could that be failing or failed causing this? I'm not sure what else it would be. Fass has flow but can't build any pressure maybe another idea, should still have warranty on it.
Any thoughts?
