Okay I’ll admit it I need assistance. Post WT mod issues.
- Replies 20
- Views 4.9k
99ramguy 7 posts
W-T 5 posts
Max Tune 2 posts
hdpwipmonkey 1 post
Popular Days
I agree. Guaranteed to cause you grief down the road. The connector damages the wire being connected into (usually breaking one or two strands) and exposes both wires to the elements which allows fo
Well you won’t believe it.. re tapping the blk/blu wire into the APPS fixed it…it makes me wonder if the ecm isn’t pushing the ground to the wire…but it’s weird because the coolant sensor which share
When you closely study the "grounding" that is shared at KEY points you'll see the redundancy that was employed in factory assembly. The W-T mod (original long explanation) is worthy of your time and
Ok, for some background, I’ve got 11 years working as a heavy wheel mechanic for the army and I’ve taught basic electrical, so I’m not a complete Mo-Ron at least when it comes to this stuff.
I completed the WT mod as well as the PCM protection fuse …
before the mod WTS would come on after about 5-6 second (I know) and truck would start right up no problem. Would do the trans lock unlock deal other wise run fine.
During the mod I noticed some real janky wiring on the APPS harness (see pics)
I repaired the broken and damaged wires and tested good continuity. Also noticed someone tapped a ground to the blk/blu wire on the apps harness so I took that off.
after completing the mod I go to start it and the WTS comes on but doesn’t shut off and when I crank the key it starts right up but jumps straight to 2k RPM and just hangs there. I have traced the blk/blu wire all the way to the ecm and it is good, I have checked for 5v to the apps (good), I unplugged my quadzilla and to my surprise the WTS light did it’s normal deal Where it comes on after 5 secs, cycles the fuel pump, and shuts off..I go to turn it on and it still jumps up to 1800 rpm immediately…all the grounds are connected..everything is plugged in, I’ve done the apps reset…to no avail…
p.s. I know the battery connections aren’t ideal I have military style lugs and terminals on the way, but it’s been running with these connection since I got it 2 months ago.
please help I need an adult.
Edited by 99ramguy
