boost elbow questions
- Replies 27
- Views 9.9k
Mopar1973Man 5 posts
Ironforger 5 posts
Doubletrouble 5 posts
Threadzy 4 posts
Boost controller opened showing spring with a check ball, unseen. behind it. Controller mounted on alternator bracket for easy access to change boost setting. It's adjusted for
No need to remove the OEM elbow. The controller works fine with just a new hose connecting it to the elbow. https://www.amazon.com/Aluminum-Manual-Controller-Install-Repair/dp/B0B5PYG6H3
I would do injectors first and soon. If those are truly OEM factory injectors they're way past their service life. Typically injector life is 100-150k miles.
02 3500 6 speed HO. 252k miles. Still has factory injectors & HX35W turbo, etc. No tuning mods (Yet. Maybe quadzilla and DAP 100hp 7X0.009 VCO injectors in the near future)
Anyhow, my questions is this: I added a boost elbow recently. How much boost gain can I expect by adding a boost elbow? I was getting 22 psi before installing boost elbow. After installing went up to about 24 psi max. Is that to be expected? Or is there a possibility my waste gate is not fully closing? Figured I'd get some feedback from you guys before I start taking things apart.
What comes first, chicken or egg? Does the fueling increase relative to boost increase? Or does the boost increase relative to fueling increase? Is a tuning mod such as quadzilla needed to increase fueling to get more boost?
Thanks
