- Replies 18
- Views 4.6k
Mopar1973Man 4 posts
JJSNOW 3 posts
Max Tune 2 posts
Doubletrouble 2 posts
JJ, I feel for you. Sounds like you've been through the mill concerning your truck. That's unfortunate. Hopefully you can take a breath and understand what ASC has told you. You already w
Contact Auto Computer Specialist. They may be able to help. They are in the vendor section.
Thank you so much!
After everything I have read on the internet I understood that the PCM off my truck had to match not only the make, model, transmission etc but also numbers mine being P56046355.
I was sold a PCM by a gentleman who swore up and down that a 2002 would work on my truck. It doesn't work and now I need some help purchasing a PCM.
Can this PCM be programmed to fit my truck?
Is this gentleman correct when he says he asked his friend who knows all there is to know about Dodge, cummings etc?
I need my truck back ASAP and I have let different people tell me different things and at this point I need to know what has to be done to make that happen.
Thank you for your help in advance!
