Engine oil in coolant and coolant in engine oil
- Replies 15
- Views 3.5k
Mopar1973Man 3 posts
IBMobile 2 posts
Max Tune 2 posts
Shimritz 2 posts
I too agree with @wil440that a rebuild may not be necessary. I've done a few oil in the coolant over the years, we call it a chocolate milkshake. the best, cheapest cleaner for the cooling system is
After your repair, fill your coolant system with water and add a shot of Tide laundry soap. Run the engine till fully warmed up (190*F). This should help on removing all the oil from the coolant syste
I've heard to use Cascade complete liquid dishwasher soap. It will breakdown the oil like dish soap or laundry soap, but without the foamy suds.....
I noticed an oil leak that came from coolant overflow tank, mechanic says oil cooler ruptured and both systems are contaminated and I have "sludge" in both systems. How did my engine get torpedoed by a non maintenance part, I don't understand???!! Planning on getting my engine rebuilt and would appreciate any input on modifications for a VP 44/NV5600 truck engine rebuild. I'm adding Hamilton cam, harmonic balancer, Cold Case radiator, BHAF, FASS 165 heated, fire ring head, custom injectors
Anyone used a DPS Turbonator VGT (s300 & s400)?? Seem very cool, but a king's ransom.
Have:
Intake manifold plate
PDI exhaust manifold 3 piece
Pusher Mega
Phatshaft 62
5" exhaust
Blue Chip Best 17X
Quadzilla (new)
Valair DD clutch (new)
Upgraded steering and front end
ARP head studs
Generally well maintained
Any input for a build for a daily driver work truck, towing rig, and occasional road tripper kind of truck would be appreciated.
Thanks.
