- Replies 26
- Views 5.6k
wil440 11 posts
Mopar1973Man 6 posts
Great work! 4 posts
Tractorman 2 posts
Trans after changing the oil and adjusting the bands now seems to be changing ok, brake accumulator now gone bad,new hydro boost arrived from Summit in 2 days to the UK Collected my AM G
I'm assuming OD works once it upshifts. That's a good sign electrically. Check the control cable and return spring maybe sticking. Next time it happens shift to neutral for a
I've seen a 46RE and a 47RE struggle to handle Idaho mountain roads. Both cases run like 15 to 25 MPH running up a narrow single-lane road at grades of 12% to 16% on average and these transmissions ar
been having problems recently with the trans in my truck (47re) sort of hanging in 2nd first time was maybe a month ago after a rather fast pull off from a standstill but after it wouldn't change up from 2 to 3 I backed off a little and it changed up, was ok for days then happened again sometimes after accelerating.
This morning I accelerated at traffic lights to beat a real slow car oncoming, did over 5 miles in 2nd and no matter what I did it would not change to 3rd
Got to my workshop and checked the trans oil, brown but not burnt, time to change it but it's not done 20k
Had to use my truck today towing my mobile workshop, set off from my workshop to the site and after a mile or so it's ok, had a few hiccups in nearly 150miles but only after having to accelerate if I was steady on the throttle no problem, couldn't help it a few times to get the truck/trailer and 4 huge Cat batteries in the bed moving
Like I said trans fluid doesn't stink but it's brown, never overheated and does not slip at all, trans supposedly rebuilt just before I bought it so done somewhere between 40 to 50k mostly towing, no codes on my 2023 software S/On Triton
I've read the 2 page old post on how a 47re changes gear and pretty much decided to get the pan off, check the filter, check the 1 to 2 and 2 to 3 valves in the VB, and adjust the bands, I fitted the 2 solenoids which are wired together (can't remember what they were for) about 18months ago seem to remember I still had one in the kit I bought still to fit IIRC
Am I missing anything ?????
Unfortunatly it's just what I was dreading as a trans repair here in the UK is not recommended, don't think it;s electrical as no codes
It has only got to last a few months as I've bought a AM General M50 6x6
