- Replies 31
- Views 7.2k
Tractorman 12 posts
Mace 10 posts
Doubletrouble 3 posts
IBMobile 2 posts
Apps relocation mod is simple. Just need some fab skills. Your not changing anything, just moving the apps from the noisey, dirty, vibraty engine to inside. Once the bell crank & cable
I set up my OEM throttle assembly complete with the throttle cable operational for a bench test. It turns out that although the OEM APPS shaft rotates 45°, the actual foot throttle rotation is about
I'm watching this I want to see how this turns out. also @Mace and @Tractorman, if one or the other of you guys maybe do an article step by step that would be awesome. (Lots of pics! I'm a visu
My name is Mace.
I'm a looong time lurker on here. Before here I was active on contributions for Dave Fritz’s site before it disappeared. I’ve been following 2nd gens since they debuted. I bought mine new in 01’ and still rock it!
I recently deleted my fb association with 2nd Gen Cummins as it’s not technical enough for me. I thrive on modifications that make our trucks more competitive & mechanically modern. The W-T mods I discovered here and installed sealed the deal to jump ship.
I’ve completed some neat modifications on my truck I’m happy to share. Here’s a couple:
• Engine side APPS delete (complete electronic pedal - no cable/bellcrank)
• Vacuum/ps pump delete to midrange pump only/remote reservoir setup
• Electric vacuum pump (Super Duty) replacement for above mod.
• Quad headlights with upgraded relay harnesses with DRL-1 module so I can maintain my drl requirement (I’m Canadian)
Anyways, hope to sponge as much info as I can. If I can help give me a shout.
Cheers!
Edited by Mace
