fuel life
i filled my tank up the day my tranny crapped out. so it is sitting in the driveway with a full tank of fuel. it could be a couple of months before i get it back on the road. how long can the the fuel sit there before it degrades and is there something i can doto prolong its life? really dont have anything else to run it in.:shrug:
  • Replies 50
  • Views 10.9k
i hope so i burnt that tank and twenty more since.:spend:
the only time you have to worry about alge or bactieria is if you have bio-diesel, if you have REAL diesel no problems:thumb1:
I have had fuel (off road diesel) for two and a half years now in the farm storage tank. I am just getting ready to refill it. (big $ this time). The tractors run fine. I have thought about algae in it but "thank the good Lord" it has been fine so far. I average that length of time for each refill. Last one was $1.69/gal. if I remember right. One farmer told me he had a problem with algae. It killed the injectors in his new John Deere, a $127,000 tractor.
your neighbor sounds like me, if it wern't for bad luck, I'd have no luck at all. I'm surprised the filters didn't clog first. Dave
He said the injectors in the new tractors are very sensitive to everthing.
:cry::broke::cry::broke:
Yea high pressure engines like the CR that is in his truck will be sesative to everything, imagine trying to push algie through a injector nozzle at 20,000psi.
Before the injector is a Edge Filter too so imagine pushing though the edge filter and then the injector... Posted Image
Posted Image
this is true however we must also realize that the edge is not as tight in tolerance as the Pinter and the nozzles are when in operation, they only move very little.
Thanks for the diagram & explanation guys. Stuff is getting even more complicated, just more things that can go wrong. Dave:mad:
as such, any older mechanical truck will take more abuse compared to a CR. our VP trucks don;'t run near the pressure that they do.
I know my mechanical Kubota will run & start on filtered wvo. I wouldn't do it in any colder weather than we are having now but I was running low on diesel & put in about a 1/2 gallon of straight veggie used oil. Today I added a lil more than a gallon of diesel to it & it's fine. It's the last year of the model change over 96 or 97 B7100.
our tractor is i think an 04 or 05 model and its mechanical injection as well?
I tend to rather rely on the AirDog filters and the stock filter to catch everything before the injection pump and injectors...
just remember that those airdog and fass filters are crap, LOL
they cant be any worse than the factory filter.
Pepsi- As I am preparing to install an Air Dog 100 next week, what would you recommend that isn't "crap"? Now is the time to hear this for me...Bob
yes they are, they are all rated for a multi pass system, talk to AHD64 about filters for the fas and airdog systems.
Pepsi- As I am preparing to install an Air Dog 100 next week, what would you recommend that isn't "crap"? Now is the time to hear this for me... Bob
A separate filter after the FASS/Airdog pump that does a good filtration, IMO while the design of the fass/airdog is good, there is to much filtering going on. For example it filters through the F/W and FF multiple times, however most of it goes back to the tank right after the fuel pump unit, why waste good filter media on that, that is why it is rated with a much lower filtration rate. Does it do its job, yes but it is marginal. Now the last that i did much research i decided to keep running the FASS filters for my FASS 95, being that if i filter the fuel first through that then it should be 90% there, then if i added something from here http://www.glacierdieselpower.com/dept.aspx?dept_id=08-001 it should be good to go. AHD64D sent me here, and fter reading his massive thread on the Cummins forum i just wish i could afford the whole thing.
Oh you would be surprised! Don't worry your not the only one that fell for the marketing ploy!
there you are! i knew it was a matter of time before you pop'ed into this thread. what do you think of this filtration kit being post FASS but pre VP-44? http://www.glacierdieselpower.com/product.aspx?pf_id=FW1220-TFK Or this one with the heater http://www.glacierdieselpower.com/product.aspx?pf_id=MK79852-BLKH
