BHAF installation pics
- Replies 45
- Views 16.6k
Napa 2790
I do not have a cover. I wash the motor all the time. Water will not hurt anything.
Install looks good!Depending on your mods that 6637 may not flow quite enough as its only rated for 425 CFM where the 2790 is rated for 680 CFM.
Yesterday I checked my air filter and found that a mouse had started chewing it. No gaping hole, but getting there. I realized that the factory air box is nothing more than a nice "mouse motel" and decided that it was time for a BHAF as they are covered with steel mesh and not so easy to eat through.I did a search and didn't find too much regarding how to mount this thing so I thought of making a steel bracket from 1.5" x 10" steel strap 1/16" thick, [see last photo]. I drilled a 5/16" hole in the end of the air filter and put a bolt with a large flat washer through from the inside and bolted the bracket to it using thread locker and two nuts so the bolt couldn't come loose (and go through the turbo). The bolt fits the hole very tight so I don't have to worry if it did happen to come loose. As you can see I used some RTV silicone to cover the nuts and prevent corrosion. I then drilled a 11/16" hole for the air filter monitor and installed it. I attached it to the fender with a exhisting 13mm fender bolt. I made that side of the bracket with slot instead of a hole, so that when I want to remove the air filter all I have to do is loosen the 13mm bolt and the pipe clamp on the other end, and lift it out.The filter sits about 3/4" below the hood, and has several inches of clearance under and around it. I did think of making a heat sheild, however, after talking to Mopar1973man decided not to. Mike says that they aren't necessary so I thought I would try it this way without one.The filter is a NAPA #6637 and was about $62 total.Any input pro or con is welcome. Always trying to build a better mouse trap (pardon the pun).Bob
