Bulk Oil Buying... Transfer pumps for Crankcase oil
I'm able to buy the original CI-4 oil without any CJ-4 oil additives or lack of them for my 2 older diesels:thumbup2: :hyper:However, I don't like standing on a ladder holding a 5 gallon bucket over my engine with a giant funnel. It won't work. :doh:So what oil transfer pumps you guys got or use? Or better yet, what are some of the tricks you guys do with bulk containers?TIA
  • Replies 14
  • Views 3k
Get a 1 gallon jug and pour a gallon into it from the 5 gallon bucket while you are on the ground. Otherwise, I would just get a manual pump from mccmaster carr.
I use 1 gal jugs. Do you want my old ones? They are valvoline pre blue 1 gal jugs.
Where are you both getting it from if you dont mind me asking
And what is so special about it?
What does 5 gal cost. I can get 1 gal for 10.00 when it is on sale. That is valvoline premium blue 15/40
That's about $15 a gallon. Do you mix it all together and use it for every thing?:lmao2:
Thanks everyone.... it made a mess for a short while till tilted up higher. Hate that :banghead:.Oh boy did my 12 valve ever thank me tonight for that non CJ OIL. Sounds lots smoother.I paid 68 bucks for each 5 gallon bucket at TARR OIL in Portland, Oregon.I'm going for a pump of some sort to make it easy. However, I did find rubber hose about the right size to screw onto the threads that the cap screws to, just like a gas can spout, didn't leak after that.Thanks for the tip for a transfer pump.Dripley, that oil's so good I put it in my wifes car after I'm done with it:lmao:
  • 4 weeks later...
Heres what I call bulk oil buying, two 2500gallon tanks of Mobil oil, one 5w30 for all the gasoline powered trucks at work, and Mobil Delvac 1600 15w40 for all the diesels.
Posted Image
-Jordan-
