- Replies 14
- Views 5k
boulder 4 posts
pepsi71ocean 2 posts
flagmanruss 1 post
hawk-eye 1 post
These OEM lift pumps (fuel pumps) are very troublesome & prone to failure. Dodge's fix was a in tank pump which was expensive & hard to service & no more reliable than the on engine pumps
the cover you are talking about is that the dome capped one with two screws coming out that is not painted black?if so then its the timing cam cover for the timing piston.
The fuel pump on my 01 has a drip comin out the inspection cover at about a drip every 2 seconds. I was wonderin if any1 else had experience with this and if i'd hafta puLl the pump off 2 fix it. I was told by a local diesel tec that its an alligator tooth shaped rubber seal thats leakin. Any help is appreciated!
