Thermostats
What is the stock thermostat temp and what is recommended? Seems I saw something on this and the guys have been changing them out.
  • Replies 19
  • Views 4.2k
    190*F is the stock temp. I change my thermostat every coolant change which normally occurs every year. (30K miles)
  • quickserve According to your ESN you got a 180°. [TABLE=class: box] [TR] [TD]Standard Modulating Thermostat - Range[/TD] [TD]84 to 91°C [184 to 195°F][/TD] [/TR] [TR] [TD]Maximum
  • CUMMINSDIESELPWR
    CUMMINSDIESELPWR
    duramax, 8 pistons with more surface areas to waterjacket=less warm up time cummins, 6 pistons less surface area to the waterjacket= more warm up time. try plugging in the block heater couple hours
Since this is in the CR section, stock is 190°, with full open being 207°, max allowed 225°.I see a 2nd gen in your sig and they are 180° with full open being at 198°, max allowed 212°.
Mine usually runs 195 but lately I have seen spikes of 205 then fan kicks and back to 170-180 range, should I change my T-stat. It use to be a steady 190 never varied that I can remember. --- I am here: http://tapatalk.com/map.php?5iasbx 2003 Ram with gauges and a Smarty! Not much more. Sent from my iPhone using Tapatalk
I would change it, that's similar to what mine did before I changed it.
Since this is in the CR section, stock is 190°, with full open being 207°, max allowed 225°. I see a 2nd gen in your sig and they are 180° with full open being at 198°, max allowed 215°.
Where are you finding the info on the tstat? Mine came with a 190* when new or at least the temp gauge used to sit rock solid at 190 except when idleing. I tried to find it in the FSM but was unsecessful.
Let me clear that up... Early 2nd Gen's (1994-1998) is 180*F Thermostat. Late 2nd Gen's (1998.5-2002) is 190*F Thermostat.
quickserve
[TABLE=class: box]
[TR]
[/TR]
[TR]
[TD]Maximum Allowed Operating Temperature[/TD]
[TD]100°C [212°F][/TD]
[/TR]
[TR]
[TD]Minimum Recommended Operating Temperature[/TD]
[TD]71°C [160°F][/TD]
[/TR]
[/TABLE]
ISX's ESN states
[TABLE=class: box, width: 700]
[TR]
[TD]B3.9, B4.5 and B5.9[/TD]
[TD]82 to 93°C [180 to 199°F][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[TR]
[TD]102°C [215°F][/TD]
[/TR]
[/TABLE]
My 05 is
Automotive Applications
With EGR88 to 97°C [190 to 207°F]
With EGR107°C [225°F]
Geez, what does quickserve no anyway. I put a cummins 180 in mine to see if that was part of my over cooling problem and it ran so cold I took it out 2 days later. My serial # is 56853981. I wonder what it says when ever you are on there again. Some places I have looked a tstat's show both 180 and 190, they just dont say which was stock.
  • 8 months later...
very informative I've had a duramax for a few years and it normally warms up even in cold weather (-deg) in about 15 mins idle I just got a 05 dodge and it wont fully warm up at idle and takes around 15 to 20 mins of driving to start to blow warm air is this a sign of a bad thermostat?
duramax, 8 pistons with more surface areas to waterjacket=less warm up time cummins, 6 pistons less surface area to the waterjacket= more warm up time. try plugging in the block heater couple hours before u depart, warm up will be less than 10 min
While were changing thermostats. What type of coolant is recommended? I`ve always stuck with the classic green in my old stuff, but the high dollar orange stuff is for aluminun radiators, heads, and such? Right?
The coolant is HOAT from the factory, which is Zerex G-05. G-05 is known to not play well with others, so I would stick with that. http://forum.mopar1973man.com/threads/1301-Coolant-Flush-on-a-3rd-Gen?highlight= As for the warm-up time. The Cummins is a cold blooded SOB, and idling produces little to no heat. Cold idling is about the worst thing you can do for a diesel engine (other than excessive cylinder heat). Cummins warns against idling more than 10 minutes on a warm engine, and no more than 3-5 on a cold one. The best thing you can do is plug it in with a timer, start it, let it run for about 30 seconds or a little more and drive it slowly.
When it's cold and I'm going to work, I only let my truck idle for as long as it takes to back out of my garage, hitch up my work trailer, close the garage door................then I'm heading down the road. Usually less than 5 minutes.
About perfect! Good oil flow to all the components, but not pumping fuel into cold cylinders for too long.
yup start it up get oilflow and then easily drive it till temp is up, this is what i do when dead cold not plugged in. plugged in i do the same but drive normally once out of driveway
