- Replies 19
- Views 3.2k
AH64ID 6 posts
dripley 3 posts
Mopar1973Man 2 posts
CUMMINSDIESELPWR 2 posts
190*F is the stock temp. I change my thermostat every coolant change which normally occurs every year. (30K miles)
quickserve According to your ESN you got a 180°. [TABLE=class: box] [TR] [TD]Standard Modulating Thermostat - Range[/TD] [TD]84 to 91°C [184 to 195°F][/TD] [/TR] [TR] [TD]Maximum
duramax, 8 pistons with more surface areas to waterjacket=less warm up time cummins, 6 pistons less surface area to the waterjacket= more warm up time. try plugging in the block heater couple hours
What is the stock thermostat temp and what is recommended? Seems I saw something on this and the guys have been changing them out.
