Going on the beach
Never took a truck this heavy before Most people are running 20psi all around I was going to do 25 front and 20 back. Here's a pic . Most people drive around town like this too and only re inflate when they leave after a week .., Thoughts ?
  • Replies 21
  • Views 5.7k
Common practice in the snow too. But with the tires deflated that low be very aware of your road speeds because the tire is flexing much more and will weaken if driven at highway speeds. Getting around town 25-35 MPH I don't see any problems with that.Like my truck in the winter time when there is lots of snow and ice I will drop tire pressures to about 35 all way around if I know the highway is ugly. So just be cautious with your road speed and you'll be fine.
Another way to verify it... After driving a distance with the pressure low measure the tire temp with your hand. The tires are hot to the touch bring the pressure up a bit more say another 5 PSI. Remember there is 1,100 pound engine up from so the weight is there and must be aware of that factor.
I used to run my 33's and 35's at about 8-11 psi for sand/snow.. of course that was on a rig that weighed less than my truck does on the front axle. That looks a little low in the front to me, I would go up to 30 unless your stuck. I run about 40/25 on mine for elk hunting and even at 40 the 5000 lbs on the front axle squashes some sidewall.
I went to pismo and didn't take any air out but I just did the river crossing and some sand with good speed not out in the deep hilly slow stuff, thats for the buggy Maybe take it out later if you need to.
After years playing in the sand along the Missouri river here in ND I found that instead of airing tires down, that traction or ladder bars were the ticket. After being in 4WD all the time in the super soft sand and wheel hopping every where after the ladder bar install on my 02 I was able to drive around on the sand in 2wd where I normally would have been wheel hopping in 4wd. It surprised the heck out of me the difference it made. I rarely had to put it into 4wd afte that on the beach and I never aired the tires down again after that either.It was purely an accident that I found this out, I put the ladder bars on for my racing and pulling but the off roading in sand and plowing through snow and eliminating the wheel hop during these activities was the best gain of all from the bars.
Bill, By ladder bars do you mean full length baja style or the little helper bars that help reduce leaf twist?
Full length, about 3-4 feet long run from frame in front of rear axle to the bottom of the axle to stop axle leaf spring wrap up. Mine were ladder bars, traction bars are a straight rod with heim joints on both ends same concept different design. http://forum.mopar1973man.com/attachment.php?attachmentid=3503&stc=1&thumb=1&d=1327271960http://forum.mopar1973man.com/attachment.php?attachmentid=3504&stc=1&thumb=1&d=1327271987
After years playing in the sand along the Missouri river here in ND I found that instead of airing tires down, that traction or ladder bars were the ticket. After being in 4WD all the time in the super soft sand and wheel hopping every where after the ladder bar install on my 02 I was able to drive around on the sand in 2wd where I normally would have been wheel hopping in 4wd. It surprised the heck out of me the difference it made. I rarely had to put it into 4wd afte that on the beach and I never aired the tires down again after that either. It was purely an accident that I found this out, I put the ladder bars on for my racing and pulling but the off roading in sand and plowing through snow and eliminating the wheel hop during these activities was the best gain of all from the bars.
How does that help pulling the weight of the truck through the soft sand ? Would have thought that would just help in less hopping as you said and better traction when in 4wd ? Ive been driving on the sand and road last two days with 25 front and 20 back. Thinking of bumping the fronts up to 30 due to the sidewall flex ...... its handling the sand ok .........
The reason for sinking into the sand in the first place is spinning your wheels and without the ladder or traction bars the axles tend to develop wheel hop from sinking just a bit and pushing the sand as the leaf springs wrap or twist they cause the axle to hop when it snaps back thus causing unwanted wheel spin. If you can prevent the leaf springs and axle from wraping up you get 100% of the traction to the ground via wheels turning versus spinning and snapping keeping you on top and not digging through or into the sand. Does this kind of make sense? I can't find any better way of describing it. It has the same results in deep snow as well. I had limited slip as well which can contribute to more wheel hop than an open diff.
Sure does. Wouldn't have thought it would have made that much difference in the sand - but good to know :) Thx boss. ok quick side question - I am going to be hitting the beach like almost everyday for 1 month. I am not allowed to wash the frame down at RV park. Nearest wash is like a 10 min drive the other way. ok to wash down every 3-4 days ??? Not really sure how much its going to help anyways since I hit it each morning whilst I am here. :shrug:
Also, the ladder bars will act like a lever and using the torque from the axle, plant the tires firmly in the sand with more force rather than lifting with wheel hop.
  • 4 weeks later...
Don't I wish... I love to be parked there and scuba diving off the beach... :cry:Truck looks good though... :thumbup2:
Me too!!!!! I have not gotten the gear out yet this year.... and don't see a chance in the near future. (I might just dive in my neighbors pool!)We could tow those lines out deep for you!!! Happy 4th!!!Hag
It's been over 15 years for me and I don't think I can get my wet suit on anymore. :ahhh:I'd still love to drive my Cummins out on the beach and enjoy the sea smell again...
Very long ago, in a previous life, I was a scuba diver / instructor...
Posted Image
Retrieving a nice old truck from Salt Pond... that's me on the running boards
Posted Image
A couple of my buddies at 60 feet off Cape Ann, Mass (photo with a Instamatic camera in a plexi housing)
Posted Image
Preping a class for their open water dive Rockport, Mass (Cape Ann) c1973 That's my 68 Road Runner...
I can only be glad I did what I did, when I did & got some pictures. Physical limitation s*ck.
Good lookin truck John.
Thanks guys. Sad it wont be going on the beach for a while now - might go back to OBX during SEP/OCT when the housing rates drop very low due to off season - otherwise will be hanging around blossvale NY for the next 4-8 weeks. Not much luck with the fish either :( but had a blast !! Thats really cool with the diving Russ. I do a bit of diving from time to time - but mainly back in australia for crayfish or when on holidays - well have to chat about that sometime back in the caht rooms whenever it gets going again !! Loving the new tires, the tint and the twins. Have some sac 7x.010 injectors in a box here also - around 150HP instead of my 75 HP ones. Plan on running those wtih the edge turned down most of time (instead of on 6) ........... and when I want more power turn it up and hope the tranny holds. :sick:
