Engine temp too high pulling my 5'er, What can I do
- Replies 31
- Views 5.8k
Mopar1973Man 10 posts
idahocountryboy 8 posts
ISX 3 posts
hex0rz 2 posts
Ok well we'll see if I can keep y'all engaged here...
The pull was from Katy Texas, Camping World RV to San Antonio. About 188.2 miles according to Google Map.
For those who may not know, it's flat, with rolling hills (I use that word loosely, big mounds of dirt is more like it). This will come into play later.
Here is my set up and whats in my sig.
It sat nice. I did pre-hook up measurements with my airlift bags. They were as fallows:
From the concrete to the bottom of the receiver hitch on the bumper
5 psi - 21 3/4"
50 psi - 23"
70 psi - 23 1/2"
90 psi - 23 7/8" (100 psi is the max but I just did 90 for 20 psi increments)
Here are the specs on my truck and trailer:
- 255/85/R16 BFG KM2's @ 80 psi rear / 70 psi front (trailer hooked up)
- Airlift air bags at hook up were 5 psi (they went flat with the arm raise, to the point i was like I need to put air in them NOW before something breaks... it was bad, heavy trailer) then pumped them to 90 psi.
- at 90 psi with the trailer hooked on, the measurement was 22 1/2" (good in my book) (trailer hooked up)
- Edge on 5x5 (98% of the time 3x3 2% of the time, I was trying Mopar1973man's set up)
- Gears 3.55
- Trailer tires Goodyear 235/70/15 (or very close to that) G load rating 65 psi
- Trailer weighs 11210 via 2003 Holiday Rambler Price, Values & 2003 Holiday Rambler Pricing Specs | NADAguides (model M-36SIT)
So we set out... First thing I notice, SMOKE ... like holly wow, that may actually put a hole in the ozone, damn! So I tried slowing down, that helped.
Get on the freeway, I-10 to San Antonio. After about 5 mins of driving this is what my panel looks like
Notice anything... yeah my engine heat is HIGH, and that was average at that point! IS THIS NORMAL? IF NOT HOW DO I STOP IT?????
As I go down the road, nearing San Antonio, those "hills" come into play. My rpms don't drop, my speed doesn't drop, but the engine temp sky rockets to the point covering the 2 on the 240 and bumping that little red line. (I don't like that).
So what I did to help NOT do that was on any, and I mean if I felt that truck even hint at wanting more fuel, I down shifted into 5th, hitting 2,200 - 2,300 Rpms... It helped a little but at 50 to 55 mph... yeah
My egts where another thing, Edge 5x5
Flats 800 - 1,200*
hills 1,000 - 1,200*
5th gear - 800 - 1,000*
Yes, I down shifted when I saw 1,200*
Got to San Antonio, the pull was very nice, straight, the Air bags were awesome, the BD Exhaust brake was amazing, the Valair Clutch never blinked with my 6 speed.
Got to the pumped and wanted to cry
That math 188.2/20 = 9.41 mpg
1) What should I do to get better MPG's?
2) How, besides Water/meth (in the plans down the road, got a wedding to pay for here in July) can I get my engine temp down? (Next haul WILL be at Edge 3x2 or less!)
I have to make it to N. Idaho from S. Texas in early July for that wedding I was talking about, with this temp issue, I don't know what to do going up the grades, in the altitude I know is coming? Please info will be nice.
