Lift Pump Confusion - 2001
- Replies 22
- Views 5.9k
Utah Dually 5 posts
Mopar1973Man 4 posts
flagmanruss 4 posts
wagntagn 2 posts
I just purchased my first diesel truck from Nampa Idaho. It is a 2001 Quad Cab Dually 5 speed with only 65K on the clock. Got it from the original owner. The only mods he did to the truck was to put a 98 gallon aux tank and some Dr. Performance injectors and a jake brake. I have been reading about lift pumps and I am a bit confused. My friend who know a little about diesels showed me the lift pump on the dirvers side of the block. But I keep reading about a pump in the gas tank. I want to protect my VP44 and make it last as long as I can by upgrading the lift pump. The Blue Chip bolt on looks like a good option, but do I have to tear into the gas tank sender and cut up a bunch of stuff also? (remember I am as green as they come regarding diesels) I thought I would never give up my 79 Chev Dually as a tow truck, but you just can't beat these things... So what is the best way to go for better protection? The only other mods I plan to do is a boost - fuel pressure - egt gauge set.... Thanks for the help in advance....
