I know there was a thread that has a good source for the filter and hose but now that I'm looking, all I can find is the filter.
  • Replies 67
  • Views 16.5k
You don't need a different hose. Maybe a few inches of sewer pipe to stiffen the clamp area. I tried some nifty tubes & such but they didn't work out. What you'll need is something to cover the stock mounting studs through the fender or a platform to sit it on, some require chafe protection against the AC line. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/24-air-system/41-bhaf-big-honkin-air-filter
So, bungie cords would be a little redneckish, huh?
Not at all. I have a BHAF but I installed an aluminum heat shield to protect it from the turbo heat. Then I installed an Outerwears prefilter on the BHAF and bungee'd it down to the A/C line. Eric over at Vulcan Performance has both: http://www.vulcanperformance.com/Big-Honkin-Air-Filter-BHAF-p/bhaf.htm The Outerwears prefilter makes the BHAF last a LOT longer and looks good to boot. :thumbup2:
I removed the 3 mounting bolts from the fender and used some pipe foam over the a/c lines and corner of the battery. Still using the stock hose with the filter clamped snugly inside it.
I resemble that comment. I've got my aluminium heat shield, foam covered A/C, lines and my bungie cord holding down my BHAF. :lol:
I have an AFE intake. It came with the truck, and the filter is NNNNNNAAAAAAAAASTY! Can I put the BHAF on in its place, or is it different? I would like to keep the AFE heat shield if I could.
You could keep the intake hose but the heat sheilds / boxes that AFE offers are all much too small for the BHAF. I think if you just took at the pictures in the thread I linked earlier, you'll easily see the differences. There are plenty of dry medium filters which would fit in your truck but the beauty of the BHAF is it's massive size.
  • 2 months later...
I have found another website to get the BHAF cheaper than vulcanperformance.com. I searched the cross reference part numbers for the BHAF and found everythingtruckparts.com has it listed under the WIX 42790 part number for $40.81. :thumb1: Shipping was also close to half the price that Vulcan said it would cost to ship to my house.
Great find! You are right. Vulcan has really raised the price on their filter. I was playing around with some other part#'s and found the Donaldson B105006 for $37.69. http://www.everythingtruckparts.com/donaldson-b105006-air-filter/ Here is the Wix 42790: http://www.everythingtruckparts.com/wix-42790-air-filter/ Thanks for the tip! :thumbup2:
What I thought was crazy when I looked at O'Reillys for the wix filter and they wanted $82.:sick:
There is a cross over list & several similar sizes will work fine. I searched ebay with all the different brands & numbers. A Fram popped up, made for Fram by Donaldson according to the slip packed with it.BHAF part numbers & cross overFleetguard AH19037NAPA 2790WIX 42790 H=11.88” D=10.5”Donaldson B105006Baldwin PA2820Hastings AF1012Afe 20-40044Carquest 87790John Deere PMAH19037Big A 93790Caterpiller 3I0005Fleetrite AHR819037Luber-Finer LAF2531Fram CA6818 (Made for Fram By Donaldson)UNI 908
Here is my set up with heat shield.post-2-138698197352_thumb.jpgI did notice with my newer BHAF the plastic is much thicker and I had to hollow out a spot so the grommet could be use. post-2-138698197343_thumb.jpg
Thanks man, you saved me $12. Once I saw this post I imediately got on and ordered one. I have an S&B that is leaking that cleaning fluid into my turbo and intake. I've heard BHAF are the best and they last a long time. Thanks for the tip. Really helped out.
Not a problem bud. Always glad to help out with saving money.:broke: Just wish I could found a turbo for less lol.
- - - Updated - - -
To all: I'm gonna check on the John Deere part number and see what my cost is on it. If I can get them cheap enough I will pass the savings onto others. Give me a couple days to find out on it and I will post about it.
- - - Updated - - -
Just so you know, I doubt John Deere will be any cheaper. They are the most expensive parts out there. I might be wrong but I think it's a pretty slim chance.
Well I'm an employee so I get a pretty good discount plus I get an extra 15% off filters in February. Picked up four oil filters for the truck for like 35 dollars:thumbup2:
Haha! Wow! I spoke too soon. How much was the shelf price?
Idk yet. Looked at it online and it showed 76.25 but where I go to look up parts Idk if it shows our cost or list price. It usually shows list but I hardly look up parts that way so I'm not for sure. I will call tomorrow and see. I just looked at receipt from oil filters and picked them up for $7.69 a piece plus tax.
Might want to ask your local Napa, when OR if they have filter sale coming up, if your wanting the BHAF Napa/Wix 2790. My local Napa has 3-4 filter sales a year. I was in there the end of last year, getting some other part. The counter guy asked if I needed any filters (FILTER SALE) sure I asked how much for a Napa/Wix 2790, he said sale is $29.00 each, at that price I grabbed two. Got a new 1 on the truck and 1 sitting on the shelf waiting.
