New revised MPG/High idle switch design
  • Replies 82
  • Views 20.3k
  • Yankneck696
    Yankneck696
    Sarah, I hope your leg gets better so that you can use your beloved truck again. The install will be pretty simple. The indicator light will indicate MG/6 Cyl/3 Cyl are engaged by the switch. Michael
  • Yankneck696
    Yankneck696
    Michael will have a unit towards the end of the week, or latest Monday. You will get to see the install & all.... Get yer popipin corn ready....Thank you all for your intrest...Ed
  • air intake temp below 32 degrees will activate 6 cylinder and below 15 activates 3 cylinder if i remember correctly
I got to thank Yankneck for taking on this project and making the improvements to the design. I've been working with Yankneck closely to make this the best version of the high idle mod. Yes. I will be producing a article really soon on how to detect high idle software on your vehicle. I'll post a link to the article very soon.
I did get a quick article put up in place for detecting the high idle software. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/26-engine-systems/436-high-idle-detecting-if-the-ecm-has-been-enabled-for-high-idle I'm going to get a video produced very soon.
I love my home built MPG (IAT fooler). It's so handy in cooler weather. It's even nice to use the grid heaters on my first morning start, then go into MPG for the rest of the day. Having it plug & play with instructions will be a great advantage to the Cummins community.
Diesel4life, would you mind getting some pics posted? If you can & actually go further to help produce this unit for your vintage truck, you will get a SEVERE discount on a unit.Otherwise, if there is no real place in your truck to mount it, the.re will be a 2" round faceplate availible to mount to a gauge pod.Thank you,
I will certainly get you some pictures in the morning. I very much appreciate the offer but am happy with what I've got for a set up. I will still be happy to provide any pictures, measurements, or anything else you may need to help you along.
I drilled a hole in my right knee panel, right next to my XZT switch, drilled mounted there.Funny thing... I keep seeing too good to be true "MPG chips" for all sorts of gas vehicles... including my Cirrus. Upon further research, they are just IAT foolers of some sort. I bet most folks have no clue what they are or when to use them.
Here is a shot of the 98-99 dashpost-11861-13869820786_thumb.jpgpost-11861-138698207871_thumb.jpgThere isn't any good spots to mount on the dash so I ended up mounting mine under the steering column. Even with my long legs it's out of the way and the wires are easily concealable.post-11861-138698207881_thumb.jpgLet me know if you need anything else!
What about a switch box that can clip to the edge of the knee panel without holes or under the steering column with the existing screw. My 01 dash looks the same as the one pictured except I have a useless storage pocket with no door & no power socket (If that is that what I'm seeing)... but it's too far for me to reach easily. I built my own GPS mount to go over the air vent.
I used 3M double sided tape to mount my little box under the column. I attached velcro to the tape to make removal of the box easy in case I need to open it up for some reason without ruining the tape.
The base for my installed Escort radar detect system is sticky velcroed to top of the column. It's a good plan.
I would also point out that for the slt laramie addition trucks with heated seats the location where you are looking to mount the controls is used for the switches that operate the heated seats.post-12849-13869820789_thumb.jpg
Personally, I have sworn up a storm dozens of times that I left the MPG fooler on, then tried to start the truck on a cold morning. With the MPG fooler, the engine is seeing 143* @ the IAT. you get NO grid heaters. Then, you whack yourself upside the head & say "WTF" !!!!! You have to turn the MPG fooler off & wait for the 25 second fuel pump run, then you get the heaters back. This is why I want this to be completely visible with an LED to indicate that a function is selected. To me, that would mean a column dash pod, pillar pod or a gauge pod affixed to the dash pad for other options. I will definitely entertain other ideas, but if it's just a "Project box", I can't have it engraved like the cubby plate & the gauge pod plate. I guess we could also produce a fully wired unit for custom mounting with some stick on engraved lables if needed. In all honesty, I am trying to suit all needs, but still keep this affordable & professional looking. I have done alot of brainstorming with Michael & Jacob to bring this product to a much more user friendly device with appealing looks, too. Of course, in my truck it'll be the best looking part, as the whole dash has disintegrated & the lower is barely there....Ed
I'll throw this out... a wedge shaped (side view) box. Velcro or sticky install. Choice of locations either on top of steering column or knee panel. Might even fit in front of the instrument bezel. I had no trouble routing wires neatly around the steering column. No holes!! Or remove face plate, reverse housing/flip switch block over, reinstall face plate. Maximum flexibility for custom installs. Less is more!Power on with key. Different color LEDs for IAT or stock? I'd be OK with stick on labels. My $1000 radar system came with 2 stick on labels depending on orientation.
I would also point out that for the slt laramie addition trucks with heated seats the location where you are looking to mount the controls is used for the switches that operate the heated seats. [ATTACH=CONFIG]6088[/ATTACH]
Dang, does that truck ever get used? It looks brand new on the inside! I noticed the white hood, Is that a different truck from the picture in your avatar?
Mornings are starting to get colder and colder around here. What's the ETA on these?
