- Replies 19
- Views 2.8k
MnTom 6 posts
Dieselfuture 5 posts
flagmanruss 2 posts
klcammie 2 posts
Is there a way to adjust timer for dome light? When I use remote to open doors dome light will be on for about a minute and there is no way to shut it off, unless I push lock button on key pad. Sometimes leaving store parking lots is annoying because I can't see where I'm going from light reflection. Plus every one outside stares at you
. It may be the way it is but I hope there is a way to change it. Lets say when I get in a truck and shut the door lights should shut off, but the only time that works if I use a key to get in, or don't luck the truck at all. Thanks for any input.
