Thermostat change.
  • Replies 16
  • Views 6.6k
Unbolt the t-stat cover, fold back radiator hose with cover attached, replace t-stat. Reverse for assembly. You wont loose but maybe a cup of anti freeze. Be sure to let it cool of and vent any pressure before replacing.
I usually drain about 1/2 gallon into a clean bucket and then do just as dripley described. If the bucket is clean then you can reuse the coolant.
Easy. Changed it. And blew out the heater hoses while I was already there!
I changed mine so often w while back I never had any miles on the anti freeze to worry about it being to old. It never hurts to check while you are in there however.
I change it out once in a while its cheap enough and better then being stranded somewhere.
What temperature range t-stat did you use? I am considering changing over to a 200 degree t-stat.
Keep us posted on your results...
I went on a trip 3.5 hrs one way in -10 F temps. Coolant ran between 198 and 206. I had my cardboard covering the rad. Iat was steady at 60. When idling it would cool down as low as 175 even with the fast idle on. As far as mpg's change I won't be able to tell. I've never really tracked that and my use of the truck is so varied from one day or week to the next.
I'm just curious about the temperature performance of the thermostat. If diesel prices wasn't so high I would be getting a 200*F and dropping it in and driving the diesel but I'm stuck driving the 96 gasser... (Cry)
Might try the 200 and see if the dash gauges recognizes it.
If you are buying an aftermarket unit and depending on the parts store and the guys ability to cross reference you may have to ask for a Stat for a MY '11 or '12.
Edited by diesel4life
