- Replies 32
- Views 24.3k
bluegoat01 9 posts
dripley 5 posts
mopartechnician 5 posts
Wild and Free 3 posts
Ok so recently changed the front crank seal on my 01 24v and discovered I need a new balancer and a sleeve for the crank but now I have a much bigger issue. Shortly after I replaces that seal a new leak appeared coming from right above the oil feed line for the power steering pump. And its a visible flow no mistaking where the source is. My question is what am I looking at right there? I can see a seem like you would see for a head gasket but I don't think the head reaches down that far. I've heard the kdp horror stories but this doesn't seem to match up with that problem. Thanks in advance for yalls help!
