Passenger Side Headlight Dim
- Replies 24
- Views 21.1k
Mopar1973Man 7 posts
bh115577 5 posts
dripley 2 posts
SecondGen 2 posts
I believe the OEM setup for Quads (Sport Headlights) is as follows: Outer lamps - 9007 low beam and high beam Inner lamps - 9004 high beam only Please correct me if I am
Second gen. You should start a new thread. You don't say if you have the quad headlights or the standard dual. (I am going off of you have the dual.) It sounds like someone
The headlight on the passenger side is dim on both high and low beam. Driver side is fine. Tried several new bulbs and even switched them from side to side to double check. I've cleaned every ground I can find, even looked under the dash, but nothing seems to make a difference. This is a 2 headlight system, not the quad setup.
Any thoughts on this? I can't afford to lose anymore hair.
