Pilothouse/RAM3500 build
Edited by PilotHouse2500
  • Replies 601
  • Views 235.5k
With the work I see you doing on your truck the company should never turned you loose. I think you'll be at a better job very soon.
Well, I'm back in business, a few wood projects to finish up I contracted for while between positions, but I started my new job 2 weeks ago.....at Cummins!  I'm in Power Gen systems (diesel gensets), but I'm now part of a great company, with cool products!  I hope to get back on the truck here in January.
some eye candy from my onboarding time at the mothership:
I remember when those trucks first came out because it was the talk of the town and local loggers, contractors, farmers where buying them up. It took till 1996 when I bought my first one.... a 92 5 spd. I drove for over 20 years. Loved that old truck.
come January when I hope to pull the '94 in the shop to start the tear down, ALL parts not on the power train are available for the asking.  PM me if you are looking for any parts before they head to the landfill or scrapper.
Well, wood projects wrapping up for the winter.  After almost a year, I'm getting back to TODD.  Last night I cut all the bracing out I had in for the roof build.  Now I can weld in new bracing so I can cut the floor out.  Then I will weld in new sill beams (2 X 4 x .125 tubular steel you can see them laying in the cab) and some cross members.  Hopefully in Feb I will be pulling the 94 into the shop and start tear down so I can get the cab set this spring.  Sure opens the cab up inside!
11 minutes ago, Mopar1973Man said:
I'm patiently waiting to see this thing fired up and rolling some day.
So am I!  LOL
goal is 2020
put in the bracing so I can cut the floor out this weekend
sooo...as I lay in bed this morning, waiting to get up (stupid brain) I thought to myself:
1.  how spendy would a manual transmission be for this project to swap in?
2. how available are said transmissions?
3.  Would my old, almost fresh off of rebuild, be easy to sell and for how much?
First off I would like to say great job, going to be a very unique truck when your done.
As as far as finding a manual should be pretty easy, and available in a reman, only thing you would probably have to pay  core charge if you don’t have one. Been looking got one myself, I like the nv4500 myself but others may tune in with different options, and $1000 core seems to be about the norm. Added to the cost of the reman.
NV4500 are very common fair priced. NV5600 are bit more expensive and bit more rare so the core prices are typically higher. Like from Six States in Boise the core on my NV4500 was nearly 3,000. So be aware rare part typically have high core prices.
sill/rocker beams in and seats out of the donor (and my helper)
From what I can see by looking at a few websites, the NV5600 was not an option in '94.  What would all be entailed going to this (assume transfercase, drive shaft)?  Altho, at almost double the cost of the NV4500...I don't know..
