- Replies 54
- Views 13.6k
Mopar1973Man 10 posts
Dave3500 10 posts
AH64ID 7 posts
diesel4life 5 posts
Hello again all,
Howdy folks been awhile since i logged in but just got back from our first trip to our favorite campsite on the lake. This was the first time going to this site with this camper (This site is the farthest and has the most hill's and curve's).
So i'll put the info up on my setup:
Truck:
2001 Dodge 3500 ex.cab LB Dually 4x4
5.9 HO Cummins 24valve 6 speed 3:54 gear's
Upgrade's:
Motor wise BHAF, Aftermarket intake horn, Fass 150gph Fuel pump, Bank's Big head wastegate, of course EGT, Fuel pressure, Boost gauge's.
Tranny wise South Bend 3250 Dual disk clutch, South Bend Upgraded Slave/Master cly.
Hitch: Reese fifth Wheel Rail's with Reese 30k Gooseneck adapter hitch
Trailer Hitch: Bulldogg 26k 5er to Gooseneck adapter
Trailer 1998 Newmar moutain air 39BRSK 40' Dual tandem rear axel's with front and rear brake's, Total Trailer weight 18,000pd's (Can provide pic of build sheet if in doubt it does weigh that much when fully loaded for a trip)
So to get to the point the truck can stop the trailer with ease (With and with out the trailer brake's on found that out by accident wire got pulled out of fitting). And taking off from a dead stop both on flat ground and on a hill is not a challenge my real issue is getting up to 55+ when getting on the interstate or just getting to speed at all. The drive from my house to the lake is about 30 mile's one way 80% is 6% grade up or down and 90% curve's( if you've ever been to kentucky you'll understand...)But after 3rd gear my egt's climb like a jack rabbit... from 800F in 3 at 35-40mph to 1150 in 4th at 45-50 mph at 30PSI boost. after i get to 55 i stay n 5th gear i know to stay out of 6th but, on most hills i got to drop to 3rd and by the time i get to the top i'm crawling to a point around 35-40 mph since it's about a right or left turn at the bottom of the hill going up. I was hoping for some insight into what to buy next injector's, Twin turbo's, intercooler, tuner??? there's so many ways to go what is my best route with this setup and it will take time as i'm alittle short on cash after the camper buying and all lol
on a sidenote the original owner who sold this camper to the dealer i got it from who then put me in touch with him bought his camper and truck the same day in 1998 for the last 15 year's he pulled this monster all over the south with a 1998 dodge 1500 excab LB 4x4 auto 360 truck...which i said BS till he showed me a few dozen family photo's of them all over the place... this man was insane my dually cummins now's it back there for a fact he was either nut's or had brass nut's to do that with a half ton but he never once had a moment's trouble...
Edited by GreenRiverCummins
