- Replies 18
- Views 11.8k
rancherman 4 posts
Mopar1973Man 3 posts
tonyjsan 3 posts
mulcher812 3 posts
I am needing to replace my “Fan hub bearing” as dodge calls it. I'm looking for some general tips / feedback etc, if anyone has replaced the fan hub bearing before. Listed below are few specific questions
1) Based on the diagrams I've found on line the “hub” bolts to the front of the engine, once the bolts are removed any surprises there I should be aware off.
2) From my research the bearing is pressed in, tips to get it out and re-isntalled. I do not have access to a press aside from a rubber mallet, block of wood, bottle jack etc.,
3) Tips removing the fan clutch, (saw one that said use c clamp to hold fan pulley in place). The threads on the fan clutch are opposite rotation ?
In past I've used sockets, pvc that has diameter of bearing I'm installing / re-installing. Read some where that's not recommended for the fab hub bearing.
Thanks in advance,
Tony
