- Replies 18
- Views 2.2k
rlane547 5 posts
hex0rz 3 posts
mopartechnician 2 posts
Ilikeoldfords 1 post
Looking for some opinions. I have a 99 with an automatic. It's mostly a daily driver and I drive like a Grandpa. We plan on buying a camper next year, somewhere probably in the 3000 to 4000lb range, to go out a few times a year. I just serviced the transmission and adjusted the bands. Everything is working like it should. I'm wondering if a double deep pan and a shift kit is necessary, or if it will increase the durability of the tranny significantly. I'm a preventative maintenance nut so the tranny will be serviced regularly with or without the mods.
Also, I'm running a stock exhaust. Would I see any benefit from a 4" exhaust over stock with my current setup? (see sig line). I don't plan on any more performance mods, looking more for keeping the truck in good running condition for a long time.
