Military testing of 2 cycle oil in diesel fuel
- Replies 32
- Views 12k
Mopar1973Man 6 posts
AH64ID 5 posts
ISX 4 posts
ctrlaltdl 4 posts
You guys got to check this out...
Below article is from...
http://www.dieselbombers.com/alternative-fuels-additives-fluids/953-2-stroke-oil-thread-13.html#post482310
After calling back the military testing facility in Manching, bavaria I got some interesting news.
-It doesn't matter what kind of Diesel engine 2-stroke oil is added. It is designed as an lubrication and cleaning aid. It burns itself cleaner than Diesel.
-recommended mixture is 1:200 down to 1:250. A higher mixture will devlop blue smoke again.
- Use of 2-stroke oil is demanded, when not knowing the source of Diesel or assuming impurities or dilluted Diesel.
This is what every 2 stroke oil manufacturer claims:
Think about it!
- Outstanding wear protection
Extended life for critical engine parts
- Enhanced frictional properties
Improved fuel economy
- Excellent thermal and oxidation stability
Exceptional engine cleaning power resulting in extended valve life, reduced ring sticking, piston tightening and elimination of pre-ignition problems
- Excellent corrosion protection properties
Longest engine life
- Eliminates pre-ignition
Maximises fuel efficiency and extends piston life
- Smoke-free exhaust
Cleaner environment
Why should a mixture of 1:50 in a gasoline engine be worse than a mixture of 1:200 in a Diesel just beeing needed as a lubing aid?
Being at the official demanded saftey inspection caused the safety officer to shook his head and to run the test twice. Emissions are 57% better than the last time. The ten year old engine is now as good as a modern engine equipped with a DPF.
This shows again that 2-stroke oil is so bad for the engine...
