Looks like I have may have lost a turbocharger!
- Replies 15
- Views 2.5k
MnTom 2 posts
FlatTwin 2 posts
Yankneck696 2 posts
CUMMINSDIESELPWR 1 post
Well everyone, was hoping that this was not the case but...
Two mornings in a row I got in the truck and started driving. Truck drove fine to about 30 mph then stopped accellerating. Did not matter what I did with the throttle and I had zero boost. I turned around and started to head home then it picked back up and drove fine. Next morning no issues. Following morning it did like above but after driving a bit longer the boost came on fine and truck drove ok...
Still this is not a good thing and finally this morning pulled the intake hose off of the turbo inlet. No real noticeable movement in the turbine up nor down but when I tried to turn it it sure seemed stiffer than normal and did not spin around as easily as I seem to remember. Am wondering if its started to coke up?
Truck has about 160,000 miles on it and this could very well be the original turbocharger. Have attached a photo of the turbo as I am not even sure if its the original model or an upgraded version. Anyone ever overhauled these? I have done them on aircraft and its no big deal but have never done this model.
Next question is, if I do need to replace this unit, is there any sort of upgrade that I should look at? The truck is just a driver, not really hot-rodded and I want good reliability more than more power.
Thx,
Joe
