Draw Straw Install and Killer Dowel Pin 24v
- Replies 22
- Views 6.3k
CUMMINSDIESELPWR 5 posts
rlane547 4 posts
MnTom 3 posts
tsmithnw 2 posts
I had two different questions and just lumped them in to one thread. First, does anyone have a good write up for draw straw install? Going to do it Friday and wanted to make sure I have everything I need. Second, I just read somewhere that the 24v's also have the killer dowel pin problem. In my ignorance I thought it was only the 12v. If so how prevalent is it? I worked for a company with a fleet of over 100 6bt and 4bt engines and never saw the killer dowel pin however I did see the bolts back out of the housing on two occasions. I guess I'm wondering if this should be a 911 issue?
