removing fuel sending unit
- Replies 65
- Views 11.6k
wagntagn 18 posts
JAG1 13 posts
Mopar1973Man 8 posts
Royal Squire 5 posts
The other option to all of this nonsense is just go to a tank sump and call it a day This is the one that I got. Didnt take me a half hour to install. The most time consuming part was draining th
Return line should be fine factory sized. It's just the supply line that is not big enough. That is a option for most pavement queens. I would just check with local laws ans see if there is
Apart from the fuel line, I think you would have a hard time damaging this thing. I will admit though that I have not checked the laws concerning where fuel needs to be drawn from. My truck doesnt see
is it possible to remove the sending unit without removing the fuel tank?I want to see how much of a job it is to increase the fuel suction lines.
