Frantz Filter being removed.
Well today while doing my oil change I finally gave up on my Frantz Filter. I've had enough. Back when I got it was rather easy to just change filters (roll of toilet paper) and go on. Well now toilet paper is so different from brand to brand and now the length is wrong, core size is different, etc. Just a big pain in my :moon: to deal with now. So I'm pulling it off and removing it permanently. I'll be looking towards a better solution in time with a remote mount base and a spin on bypass filter some wrote up in the past. The other thing is I'm tired of the leaking lid all the time no matter what I do I've always got oil oozing out of the can. I'm tired of the oily mess and fighting the toilet paper rolls.
  • Replies 67
  • Views 13.2k
  • Per the request....   One photo shows the installation of the spinner - mounted to the top of the alternator mounting plate. A second photo shows the drain line to the unused 'boss' (that has a kno
Any thoughts on what you will do to precede?
I should of measured the hub of the Frantz Filter and seen what size of roll I need to fit it snug again so next time I hit a WalMart or similar I can measure a wide variety of brands to see if I can hit a better roll. Still leaves me with a leaking can issue and finding the square cut o-rings that are better. I've got another 4 or 5 o-rings left and they seem to be leaking by the next oil change. Messy SOB. That why I still going to do more reading and research. There has to be a cost effective solution. Something that doesn't need to be cleaned up like spinner and Frantz. I really do hate the mess you have to deal with and leaks. Spin on filter are more appealing but "specs aren't good enough".
So I have to say... These industrial applications that use these spin on bypass oil filters must be good enough for something. Being most of the application list is diesel engines that these filter are used for.
Many of them may have been better than older full flow filters, with older oils. Why run a 10um nominal bypass when you can run a 7um nominal full flow?? Older filter media was low on flow and filtration, so a 10um bypass may have been better. New media is much better, something that is needed with higher engine ratings. A 160hp 5.9 is much easier on oil than a 300+hp one.
Just like the original FASS and Air Dog filter, just because they have a WIF drain doesn't make them better than OEM.
Application and ratings are very important.
  • 3 months later...
I know this post is old but what ever happened Moparman did you switch? I just ordered a new bracket to relocate my frantz and I ordered some synthetic TP for 9$ and change. But i am to having a big problem with mine leaking from the canister I just changed the gasket so we will see. Do you think its because it mounted upside down? But I understand about it being messy it takes me longer to change the Frantz than BOTH my fuel filters. I was so angry last night i was going to get rid of it but looking at the cost of amsoil I will just make it work.
I think the new gasket will help. Read somewhere to change every other TP change. Under pressure, so I doubt it's because it's upside down. I getting better at changing mine without loosing oil.
It was different when Deborah was down in Nampa, ID I could call up and get seals next day in the mail for cheap price. Now that she sold it I'm not sure what its going to cost for seals.
here is a link
http://www.frantzfilters.com/product/base-gasket-10-pack/
14.95 for a 10 pack of seals.
their customer service is nothing like Deborah's either. I bought a new shinny oil cap from them and not anywhere on the web page does it say you need certain equipment to make it work so then I snapped my swivel bolt from my old cap completely off. In which I had to drill out and re-thread the cap and  I called them to see what heck and no one could talk to me until Monday. I had to completely remove the frantz to drive my truck. when they did call me the guy said it tapers down and the use a quick disconnect on the return line. That would have been nice to know when I bought it.
Also off the subject but the synthetic TP is rated for 10,000 miles even for a diesel.
Edited by ADawg
Well I've come to love the Baldwin BD7317 oil filter. Bypass filtration built into one unit no extra hoses or possible leak points. Also Blackstone labs seem to think it's doing a better job on the truck compared to the Fleetguard LF9028.
I am not sure I am 100% sold on those. Fleetguard/Baldwin only spec them for stationary engines.
I've gotten pretty good at changing my frantz without spilling a drop of oil. Seal only needs to be replaced periodically. I got a 12'pack of Scott paper for like $6. Pretty cheap. Now with the sale of frantz I know purchasing a new system has become EXPENSIVE! I doubt I would buy one at the current cost of like $400.
You are correct I have called Baldwin and spoke with them and they told me it's approved by Cummins.
My local Cummins facility says the LF9028 is approved and recommend for use on all 5.9L engines.
I've ran both filters and the Baldwin BD7317 seems to be the better of the two also its cheaper and easier to source.
But what is the service life on them??
If you go to the Fleetguard site it sure doesn't look like they are approved for all 5.9 applications.
https://catalog.cumminsfiltration.com/catalog/PrinApp.do?reqCmd=PrinApp&partNumber=LF9028&mfrCode=FLGRD&linkClicked=2&partflag=0&partflag1=0&forPartNumber=LF9028
They are a great filter but the application may be wrong. It is unknown what kind of service life they will have in an automotive application.
The Fleetguard variant has a 30 micron absolute rating and if I remember the bypass portion is either 3 or 5 micron.
I will double check the info for the Baldwin but I believe it's absolute micron rating is 20 and the bypass is 5 micron. I've got tech specs on the Baldwin on my laptop I will double check tomorrow and let yall know.
I cant get to page 3 of this thread data base error?
double post
Edited by ADawg
I bought a Fleetguard centrifugal oil filter and gave it to a buddy who was going to fabricate a mount and source the fittings and hoses.  I haven't asked him about that in ages.  I will have to ask him about it and see how much he has done on it.
I added a centrifugal oil filter for my 2002 truck.  Very happy with it!  I did a 4,000 mile trip - and on return, measured the amount of 'debris' it captured in that 'short' distance.  The debris weighed about 0.8 oz....Realistically - the spinner doesn't need to be removed and cleaned frequently...I figure I might do it every 12K to 15K miles, but I could probably extend it to 20K to 25K, based on the amount it will capture/hold.  These spinners are rated as excellent for removing particles down to 1 micron....and once installed...no cost to buy replacement filters.
I bought a Spinner II (before I found a lower cost unit ..).
I found some 3/16" plate steel (about 3" wide, 13" long) - and I shaped it into a "lazy s" by using a hydraulic press, blocks, curved pieces, etc., until the top piece curved along the alternator bracket, and the lower piece was horizontal. I put a 1/4" aluminum plate on top ...drilled 4 mounting holes, drilled a larger hole for the drain - including a 1" NPT threading. Install a 1" NPT x 1" barb fitting.
Use 1" stiff hose for the drain line, good for 300 psi and 300 deg. (IIRC). About 3 ft. long. At the lower end - a 7/8" Block Oil Drain fitting to go into the block just above the oil pan and just behind the engine mount. (BOD from Vulcan, about $10.)
For the oil feed to the spinner, use suitable high pressure, high temp oil line to go from the spare oil port next to the oil line going to the turbo.
Let me know if you have any questions.
