silverram323
Everything posted by silverram323
  1. X2 im looking at his new 188\220 Sent from my mobile phone using tapatalk
  2. If you didnt have guages, hands down a quadzilla adr, but since you have guages I would go with the ol edge comp, I seen them go for around $300-$400Sent from my mobile phone using tapatalk
  3. Someone told me the rim offset is different and will hit the brakes.I was thinking if I take my truck pulling tires of my 01 and put them on my dd 95 12v, money is tight and it will need some new shoes before snow flies.Sent from my mobile phone using tapatalk
  4. Does anyone know if I can bolt on my 2001 rims on my 95 ram? Will it clear the brakes?Sent from my mobile phone using tapatalk
  5. I have broke 4 dana 70 axles while pulling, (all at the splines) I changed the side gears to 35 spline and run d80 stock axles. I think im just going to swap in a d80.Sent from my mobile phone using tapatalk
  6. stealer dealer wants $180 for it new, im calling around now at junk yards. Anyone parting out a 1995?
  7. I need to know what this part is. I went to the local parts store and they/we think it is brake proportional valve sensor. When i was chasing wires on the 7 prong rear plug wasn't getting power i must have bumped it and broke it off, now my ABS and brake lights are on. can i buy just the sensor or do i have to buy the whole thing?
  8. Wow you dug up a old thread, it would be nice to hear if he found the problem.
  9. Here is my setup. Not sure what others get for MPG towing heavy but in stop and go traffic, and 7 miles on the freeway i got 12.4mpg with this setup, I'm guessing 22k total
  10. It fits like a glove, no problems what so ever. I also took advantage of the taking the drivers seat out to get the rear seat out, a little rust control. Ill take a pic of it painted and installed tuesday.
  11. I have the rear seat storage on my 01 and was wondering if any one knew if it would bolt right up in my 95? 2001 Posted from my mobile phone while not driving....
  12. I wish all my problems were solved that easy. Glad its fixed.
  13. Did you forget to take out the relay and put your jumper wire back in? I did that once and it caused limp mode. Just thinking out loud.Posted from my mobile phone while not driving....
  14. YesPosted from my mobile phone while not driving....
  15. I had a intermit problem like this also, it turned out to be a cracked fuse on the engine fuse inside the cab. Worth a shot to change the fuse.Posted from my mobile phone while not driving....
  16. Well the problem is, when I leave the truck I have tinker with it to keep it from chiming. Then in the morning I walk up to the truck and I can hear it going off. I think it's in the ignition switch. No one else has this problem? It's like the switch isn't off and there is a fine line as to where it shuts off. Anyone know anything about the keyless entry? I have 2 key pads and one worked 1 time and I put new batteries in it and now both don't work at all. Any way to reprogram them?
  17. I have to wiggle and giggle the key switch so the dinger dont stay on all the time, even with the key out. Same dinger as when you leave the lights on and open the door. Any ideas?
  18. I dont have much time to work on it as im working 90+ hrs a week, however i did get the KDP done last night. I saved the file on the computer and I will look it over for a next weekend project. I printed out pg 11 and 12 as thats the exteriror lighting, looks like a mess, I hate wiring....:doh:Thanks.
  19. How much do you need for a set shipped to 55092? Posted from my mobile phone while not driving....
  20. I think a 90 hp injector, quadzilla/edge comp, and a 62/71/14 (sps 62) is a great towing setup. It netted me 535 hp and 1200 tq and I had to problems towing my LQ 4 horse gooseneck trailer.That would be my setup for a dd/tow rig.Posted from my mobile phone while not driving....
  21. Thanks, I dug around under the dash and the wires under there are small guage (16) compaired to the brake controler wires (12 guage). why cant it just be simple.
  22. I just picked up a 95 12v as a tow rig for my pull truck. I pulled out the controler from my 2001 and thats a plug and play. I looked under the dash of the 95 and I dont see any similar looking wires.. Help pleasePosted from my mobile phone while not driving....
  23. Sent from my Kenworth T600 18 Wheeler
