YabbaDoo
Everything posted by YabbaDoo
  1. I think I can see behind me now:cool:
  2. Not a fan either... The 1500 brakes SUCK!!! I did install cylinders for a 2500 in the back that have helped...bit they still SUCK!!!:banghead: Tried everything... Replaced booster, master cylinder, Drums, rotors, pads, shoes and even the lines...Installed the cylinders for a 2500 and it helped a little....
  3. Not a Town Car... Bleu is a 1991 Continental Executive:) And she does drive like a dream And gets up to 27mpg while doing it too... - - - Updated - - - And, Thank You:)
  4. Welcome!!! Loved the story and look forward to hearing more!!! Your Truck sounds Awesome!!
  5. I do what I can - - - Updated - - - Switched the topper over from the other truck too:thumb1:
  6. Don't know when the previous owner changed it last, but I do believe it was time!!:hyper: - - - Updated - - - Oh, and got the topper on today as well!!! Getting ready to head to the mountains!!!!
  7. You most certainly will see deer up ahead.... Soooooooo, How do I acquire a set of those:whistle:?
  8. My 97 looks to have the wiring already in place. I think my 94 does also but I wired with aftermarket lights 11 years ago and don't remember, but I will look:)
  9. Sounds like problem I had in my little truck with the neutral safety switch behind the clutch... Drove mine with the paper clip fix for months till I got around to getting a new switch...
  10. I remember our cars were covered in ash down in Southern California from Mt St Helens
  11. Welcome!!!
  12. Installed more lights:hyper: The color can be changed:thumb1:
  13. Love the pic!!! Looks like a fun day!! Was in the high 80's here today:banghead:
  14. Impressive!!! Name one car that could do that today...
  15. azFNG... I am learning as well... Wrench on all my gassers, but learning all about my new Cummins I am having a blast!!
  16. With mine when I first bought the truck, I would have to turn the key in the on position and manually lift the solenoid then start the truck... The guy said he bought another one but the new one didn't work... S I started looking at what else it could be and found it was just the 70 relay 10.00 fix
  17. Hello, I just bought my 97 that had the Fuel Shut Off Solenoid issue... Lucky me it was only the relay:hyper: I also rewired the fusible link wire that comes off the battery due to the eyelet being corroded. Sounds like a nice truck all in all....
  18. Nice job!!! You are lucky you have a splitter I did a pile that size 2 years ago for my Uncle the old fashioned way using a 16# Maul:thumb1: Great workout though:thumbup2: It doesn't get cold enough here to have a more than a couple of fires , so need in chopping all that wood:(
  19. Ok... This has been my yard and pasture for the last several months... Water and Mud... Had a nice sunny 92 degree day today though:banghead:
  20. Just changed mine.. Neutral safety switch... Was only 12.00 at advance order online and use the code trt30 and save 30% - - - Updated - - - http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_neutral-safety-switch-bwd_20971212-p?searchTerm=neutral+safety+switch - - - Updated - - - You can check it by unplugging the plug from the sending unit, put a jump wire between the first and third terminal while the key is on and if it works replace the neutral safety switch, if not you have another problem... And don't forget to check the 15 amp fuse in the breaker box:thumb1:
  21. Pleeease..It is 80 outside right now.... Can't wait for vacation in 2 weeks... Head up to the mountains to camp and hike...Hope to wake up with frost on the sleeping bag:thumb1:
  22. Sounds like what I had going on with my GMC. Granted it is a 4 banger... However it ran perfect and still got 21mpg, didn't smoke but thought it was time to rebuild the engine after 453,743mi (had a slight knock) Turns out had a burnt piston... Thought I would mention it... I do know that Pasco Auto Salvage has a Cummins sitting waiting for a new home for about 1800.00
  23. Actually those are OEM... I think it is just the way the camera caught the pic.. Wish they were that bright!!! I am going to add another light on the hitch frame for direct light behind the truck:wink:
  24. We shall see:thumb1: But maintenance and cleaning will be a must:wink:
