Everything posted by Royal Squire
2002 Dodge Ram 3500 24v manual- Issues - Need Help Please!
Yes grid heaters cycle after truck is running, you can watch your amp gauge and see it.
Mr. And Mrs. Michael S. Nelson has occured!
Congratulations. Best wishes for the new year
Yoke Grenaded
Wonder if the transmission seized
Edit profile
Thank you. I got it. Hard to see pencil because of photo. Congratulations on your upcoming wedding and cancer free status.
Edit profile
@Mopar1973Man-Mike can you tell me how to edit my profile. Canāt seem to figure it out. Iām using my phone. Thanks-Kitt
ECM or something else?
Could this be a starter problem since it starts so easily when rolling and popping clutch ?
Help with Quadzilla 3 cylinder/6 cylinder box
@LtkDoes the 6 cyl high idle work?
Been a little absent lately.
So sorry for your loss. Really hard when you have a great dad.
Is my grid heater dying?
Sometimes starter can be lazy and doesnāt spin fast enough.
Pilothouse/RAM3500 build
What I was trying to suggest is using the corners as in the 1st photo and drilling holes in rear for center 3 lights which would likely eliminate center rear stake pocket. I believe that most stake beds donāt have a center pocket anyway. Just my $.02
Iām recommending using the corner lights and duplicating that look with the three center lights. Worry about stake pocket later
Are you putting lights in the bed corners?
Aux Lighting and Negative Switching Advice
Can you share any photos?
turbo output to firewall allowable gap
@PilotHouse2500That sure is a nice panel. Did you form it with a wood buck?
Forced high Idle
In the 2nd gen if I understand it correctly the smarty can activate the high idle option without the VIN lock.
New High Idle Switch
I had my 3 cyl high idle work once just because it was cold out but donāt remember how cold. So you could just wait for cold weather.
Since enabling the high idle was a TSB it is possible that it has already been enabled.
Yes or you can use a smarty. I think DAP has one they rent out.
shift boot location on tunnel
You owe me a ride when truck is done šš
@PilotHouse2500 Sorry I meant to get you a photo today but forgot. It will be the weekend before Iām back home. Photo will be of a V10 truck which I believe to be the same. Hope that will be soon enough.
Need older SB Mopar pic
@IBMobile-Isnt your photo of a big block, 400 or 440? I believe small block mopar has a rear distributor.
The Cummins is back.
Better target?š
Poor fuel MPG
@Tractorman John - What did you run for speed on that trip?
Finally decided to add cupholders! We shall see.
I purchased one of these from Amazon a few months ago. I think I paid $28. I like it also. Wish I would have done it sooner.
