Everything posted by Royal Squire
I know this is sudden but...
Keeping you in our prayers
NV450 5speed blew at 184k miles.
Curious how much $ you will have in this rebuild?
Tranny swap
If you look long enough on line, there was a guy who put a 13 speed in a 2nd gen dodge. Had to make a lot of modifications. There is a good article and photos if you can find it.
Fuel hose anti spill valve needed
@LD-OrdieThat Perko check valve is on Amazon
Vacuum lines?
Somewhere on this site is a schematic of those vacuum lines
Death wobble issue rears it ugly head again
If it were me I would lay under the front end with a good light and have someone work the steering wheel back and forth with enthusiasm while you look for loose parts. Just because track bar isn’t very old doesn’t mean it’s good.
P1291 No temperature rise seen from intake air heater
@Nomad2015I’m sorry you’ve had a bad experience. @Tractormanis very methodical at diagnosing problems. I’ve been hanging around here for years and this is the first time I’ve heard anyone say people are nicer at Cummins forum. I think you’re making a mistake going away mad. Just my $.02.
Pilothouse/RAM3500 build
I believe they flip the manifold when adding twins
boost elbow questions
Don’t you Nepali boost fooler to increase boost?
Finally got to tow with the compounds.
Is that your Christine?
NV4500 oil type
Does anyone know anything about “Ultra 1Plus”?
So, I got gauges for Christmas!
If you don’t already have a boost bolt it’s easy to drill and tap your intake elbow, that way you don’t over tighten boost bolt and twist it off like I did!
Fuel Filter Housing
It’s a fleet guard part. Just do an online search for Cummins filter drain.
Last minute prep for first measurable snowfall
I ran across a real biker the other night, well I didn’t really see him/her but saw the bike. I was passing through Craig CO and stopped at the local Walmart. Setting out front in the snow, at -6*F was a bright yellow full dress bike. Would have taken a picture but left my phone in the pickup and was anxious to get back on the road. 🥶
Is there a foolproof way to tell if I need a heater treater?
I see @Doubletrouble. Thought I would try to save you some money 💰
I believe somewhere on this site is @Mopar1973Manwinterfront. Easy to make and nearly no cost.
New theme for Mopar1973Man
I use an iPhone and like old theme better. Could be that I just don’t like change!
Miracle Oil-Front Axle Seal
There used to be an article on this site on front axle seal replacement
It’s easier than you think, especially since you just had wheel bearing out. That’s the hard part.
Compound Turbo install complete
Only problem with the recording is it doesn’t set you back in the seat 😁
Delayed start - longer turnover.
Does it start the same if parked uphill? Also cranking speed can slow down gradually and you may not realize it.
Towing a large bumper pull on Monday
Is 24 volt truck the reason brakes don’t work?
Engine cooling fan failure
My neighbor was driving my dodge the other day when one of the fan blades broke off and hit the radiator. I haven’t seen it yet but that’s how he described it. Anyone else had this happen?
COVID Deaths after being Vaccinated
I’m unvaxxed and have had COVID twice(assuming the self test is accurate). Second time was very mild, mostly scratchy throat and headache. Didn’t seem to affect my energy level or taste/smell like the first time.
Squeak/Screech noise in reverse only
Looks to be a lot of difference from one adjuster to the other. Don’t know if this is a good indicator or not.
