Everything posted by Royal Squire
Anyone enabled the ecm high idle lately?
Can you still rent a smarty?
Grid Heater Stuck On
Hard to beat free shipping!
Turn signals not working
Took the first flasher back to oreillys and told them I thought it was faulty and they exchanged it. Turn signals are now working. 😎
2001 Auto Upgrade Plans - Turbo, Injectors, Quadzilla, Gauges
Looks new. $300 would be a good deal even if you don’t use it. You could likely double your money.
Installed new multi function switch and still no turn signals but hazards still work. Picked up a new flasher, now hazards don’t work unless I reinstall original flasher. I’ve checked all fuses and everything is good there. Anyone have any thoughts?
Sorry Everyone I haven't felt like participating much Lately.......
You could become a garage cleaning monster 😂
Chiropractor helped me immensely with my sciatica. Prayers sent🙏
Trailer is unhooked and blinkers still don’t work so I’m gonna try multi-switch
Grid heater bypass question.
I got a new solenoid under warranty and will try again.
That’s how I had it wired. Guess I’ll start over
Does it matter which large terminal battery power is connected to?
Solenoid doesn’t work and smells burnt.
@IBMobilethis question is for you. The solenoid you recommended (ss598) is a different style than the one you used. Does this matter? Seemed to work fine when I first installed then me wife took truck out of town and commented on how hard it was to start. Solenoid doesn’t work now. Any ideas? Did I just get the wrong part or...??
Installing air springs, hose question.
Interesting license plate
Doesn’t seem to be intermittent any longer. This al started when towing a trailer. Don’t know if that’s related. Guess I’ll order a multifunction switch. Thanks for the help guys.
Turn signals on my 2000 not working and seems to be intermittent according to my wife. I haven’t looked at it yet. Emergency flashers still work. Any thoughts?
Happy Birthday - Fifty Years Old... Ugh!
Just think-60 is only 10 years away!! Happy birthday ????
What I have done/found on Ole Blue today
I admire your tenacity. Couldn’t you have rented or borrowed a mig welder?
NV4500 locked in 4th
May have been speed shifting!
Grid Heater Bypass Simplified
Completed this mod today. Works great. Wish I had done it sooner. Really easy, even for The electrically challenged. Thank you @IBMobile
- 3 comments
- 1 review
- 2
Tire Size / Final Drive Ratio - Reality Check (More-fun-with-math!)
Just pull the cover and count the teeth. Divide the drive gear into the driven. I believe ratio is stamped on ring gear also.
Could go with a quad and tune out smoke. Still way cheaper than gears
I’m with @NIsaacs Changing gears is a lot of money for not much result, but it is your money.
VP66 shenanigans
What about the VP55??
You should probably make sure gears haven’t been changed previously
