Everything posted by Royal Squire
Rear view mirror fell off...looking for adhesive recommendations!
FWIW Years ago I glued a mount on with permatex rear view mirror adhesive upside down and it wasn’t coming off. I attached the mirror thinking I could pull it off with the mirror. Nope! I ended up getting another one and gluing it to the first one with the mirror adhesive. Worked great. It’s been a few years since I’ve done one but I’ve never had one fall off when done properly.
My haul trucks/trailers
Thanks. I need some new tires soon and road/driveway is pretty rocky/rough. Just wondering what you were using.
Vac pump heads up
Mike has seal kit here on site in the store
Im curious what you run for tires on the trucks?
Economy Car Or Diesel Truck to go shopping...
Do I smell burning feathers?
New front end noise, how can I diagnose the front end?
I have heard other guys say they have seen bearing assemblies that seemed ok until they removed axle nut and then it was obviously shot.
I’m guessing wheel bearing. Jack up and take wheel and caliper off and then check bearing
0237 map sensor code
If I remember correctly I had this code one time and had a small amount of corrosion on edge ez connection
Hi from New Zealand
DAP likely has Isspro gauges in stock for fast delivery
Fuel pressure 5psi. 0 at WOT
For some reason not all vp44s will operate without a lift pump. Don’t know why but without lift pump my truck starts to run rough and dies.
Looking For a Good Vendor
Could take the innards out of the fass
Moose Horns (Towing Mirrors)
That’s strange. My passenger mirror adjusts just fine.
If you don’t have gauges I would recommend getting some.
RV275s: engraved or inked?
That kinda looks like laser etching
Synthetic VS Standard oil
Do you have any examples of barely synthetics?
Getting rid of the rust
I thought you were talking about front bumper
I believe you can buy those bumper brackets on line
John Deere 455 Fuel Filter Fittings Problem
Got a photo?
Did I fix everything?
It was setting on a slight incline toward CAD, then moved it about ten yards and BAM vent made a mess.
Bhaf really has some suction!
While you all are talking about axle vents-can anybody tell me why my front diff would push oil out of the vent? I wasn’t even driving it. Had it running on high idle while I charged a.c. It was in 4 low but I don’t know why that would matter. Guess I know it’s not plugged!
Pinion Seal Replacement, Noticed differential shaft has a lot of play.
If pinion wobbled before removing nut you have a bearing problem.
AC Replacement
@IBMobile you say not to use pag oil on o-rings, what oil should be used in compressor?
My trip to Mohave, AZ
Milwaukee is good. They have both a 3/8 or 1/2” impact and also 1/4 or 3/8” ratchet that is very handy.
Even the peanut butter pours!
