Everything posted by Royal Squire
2001 Auto Upgrade Plans - Turbo, Injectors, Quadzilla, Gauges
Welcome to the forum. While I’m not an expert, my advice would be, before adding power make sure your transmission is up to handling that power. If it was me and I was swapping turbos, I would likely use a hybrid like @Mopar1973Manor @Dieselfuture. For me, a fuel pressure gauge just gives an added sense of security.
Abs question
If you know someone with a snap on scanner I believe it will read abs codes
Lift pump control guidance
I just don’t want to go through the bad ECM but I guess there’s no guarantee either way. Thanks guys
Mounting a 70 gallon Freightliner tank in the bed.. Suggestions/Ideas?
Looks great. Do you have mounts figured out?
Approximately a year ago my lift pump(Raptor)quit working because my ECM was misbehaving(WTS light only working part time). I hot-wired lift pump through a switch as I needed truck. I have since had ECM repaired and all is good, however I would like to know what the folks here would suggest I do with lift pump power. Should I hook it back up to ECM, through a relay of course, or should I use @IBMobile ASD wiring article for lift pump power? I’m kinda apprehensive about hooking to ECM again but that would be simplest. Thank you in advance for your suggestions.
Fuel mileage with new injectors
If you unhook batteries I’m pretty sure it resets trip meter
1999 ram3500 2wd ifs camber correction?
I was wondering why it wouldn’t be adjustable
NP241 DHD tailshaft bushing part number
For sure it won’t leak if empty
Oil change
I believe it is DBL 7349
Can someone help with factory height
Borrowed trailer from my neighbor
- Truck bouncing with load
B&W makes a 4” extender(made to give more room in short bed when towing gooseneck) but would allow you to move ball forward to see if that helps. Assuming you have a B&W gooseneck hutch.- Anyone paint or dress up their Cummins? Let's see some pics!
Fender well headers on a Chevy truck?- Can someone help with factory height
Hook a trailer on and it will level right up- Need help
I believe you need to be a member and then you can download service manual that has wiring diagram- Anyone paint or dress up their Cummins? Let's see some pics!
Since you’re showing off a Chevy, this is the engine in my son’s 64 pickup. He has a long way to go as he still needs to get computer to work on a budget. In case you wondered my Cummins is not as well detailed!- Moving to almost the great white north.
I think it was delivered to my address by mistake!- Moving to almost the great white north.
Where is the “white”?- Bleeding new VP44 and injectors
If you just installed these injectors you might call DAP and talk to them. I had a bad miss after install and they sent me a another set quickly and just asked me to return first set when I got a chance. It wasn’t convenient that the first set didn’t function correctly but it sure was nice they sent me another set right away at no charge and without having to return the first set.- Sway Bar Bent
Seems odd it would be bent unless it’s been in an accident- 47RE Build
How much does trailer/payload weigh?- Considering buying a deleted 6.7. What do I need to know?
Depends what County in Colorado your moving to. Some do emissions and some don’t- 2-stroke oil on sale!
In NW colorado diesel is cheaper than regular unleaded. In some places $.20 cheaper. Anyone else seeing this?- Partial dead pedal???
Could be your tuner acting up- Air bubbles only visible on rear brakes when bleeding
@Mopar1973ManDo you change the fluid in clutch master at 30000 miles as well? - Truck bouncing with load
