Royal Squire
Everything posted by Royal Squire
  1. Seems like a while back there was another member who ran across the same thing when installing new fass
  2. Probably could rent a trailer and haul them both at same time.
  3. Mine is that way especially if it’s cold. If you raise rpm it will get fluid flowing.
  4. Pictures are best. Then there is less confusion-maybe!!
  5. When I had coolant leak the fan was blowing coolant everywhere and until I pressure tested I was really worried it was head gasket.
  6. I thought I had head gasket leaking but turned out to be water pump. Rent a cooling system pressure reset and pressure up cooling system and should be easy to find.
  7. There is a fuse in the pdc under the hood that may be the culprit
  8. Didn’t want to take axle shafts apart as u-joints are still in great shape but I guess sometimes......
  9. Not really alongside road. Actually took axle shafts out at home and then drove to town and one of unit bearings came apart. Should I have taken axle joint out and put outer shafts back in to hold bearings together? Was hoping to rebuild diff later on but still be able to drive truck if needed.
  10. I had pinion bearing in front diff go out and need to get truck home. Hopefully one of you smart guys can tell me if I can just pull axle shafts out and drive truck that way. Any suggestions appreciated.
  11. Those shocks are kinda severe angle aren’t they? Please explain
  12. I used the boost bolt and torqued it as recommended in instructions(it came with my gauges) and when it broke I drilled and tapped elbow. Had it off to replace injectors. Boost bolt broke when I was removing it.
  13. Might take to frame shop and they could tell you where problem is and if axle may be able to straighten it.
  14. Is your Wait to Start light working correctly? It should always come on immediately when you turn key on.
  15. Now that is social distancing! Wish you well. Looks like a great location.
  16. Sounds like one of those many items that it seems manufacturers would install on all campers.
  17. What is purpose of accumulator tank?
  18. Easy to remove stock muffler if you want to change sound
  19. There is a factory service manual on this site that should have all the info you need
  20. WTS should come on immediately when you turn on key
  21. That’s what I was wondering. No way to know the real numbers
