Everything posted by Royal Squire
Truck died second version
You can use the OBD 2 to check for codes. The DRB III is pretty pricey.
RV Vent Insulating pillows....
Mine stay in well and crank isn’t an issue
Tuning help just bought a cummins
Or starter
New truck
Be nice to keep both of them. At least you still have a photo of the old one.
Uneducated second gen owner in need of help
Might want to get a test gauge to make sure you have fuel pressure.
If I were you, knowing what I know now, having learned a ton from the good folks here, this is what I would do. First of all, unless the tires are going to leave you stranded, I would put that on the back burner. Yeah they would look good but if the truck won’t go.....my first purchase would be a fuel pressure gauge to make sure I’m not starving VP-44 injection pump. Next I would check for AC voltage and do W-T mod, both are in articles on this site. I would also check and clean all grounds and batteries and battery terminals. These mods are very inexpensive and simple to do. If you need a fuel pump I would likely go with a mechanical since the electric pumps seem to generate excess AC voltage if I understand correctly. Just a few of the many things I’ve learned from this site. Others may have different opinions. Listen and learn from someone else’s experience. It’s much cheaper!
Smashed vacuum line and a mystery hose.
Unless I misunderstand your dilemma, you can place #1 plug wire in any position on the distributor cap as long as the other wires are in the correct firing order and you take into account the direction of distributor rotation
New to me truck
I believe if you know someone with a smarty they can program your tire size. Not sure though
HELP
Might be starter solenoid fuse in power dist. center on left fender well
NEW FASS Signature Series Diesel Fuel System "What are the Big Differences"
I was thinking the same thing
Towing...Your Experience Is Appreciated 98.5 24V 2500
Snap On tools are the best
No argument that they are good tools, it’s the price that is sometimes hard to swallow.
P1698 No Bus, truck still runs
You might try cleaning all connections on PCM and instrument cluster. I think a poor connection on PCM is what caused my “no buss”.
Bd 3 peice pulse manifold
Cracked manifolds are somewhat common so at some point you, or someone you know, may have a cracked manifold. That justifies it right there!
47RE In-chassis Upgrade Recommendations Wanted
Valve body is more like the brain of transmission. Without the transmission oil pump the valve body is dead.
Hard start in morning, then good rest of day
You might want to get in on the injector raffle!
NO BUS message on odometer
YeeHaa!! It’s running again. ACS said nothing wrong with PCM they just had trouble getting it to connect. They told me not to use dielectric grease. $150 to test. When I hooked everything back up I had 16 codes. They all cleared except for P0237. I disconnected my edge and cleaned all connections and all is good. Thanks for the help. Sending a donation today.
Homemade pop off testers
There is someone here that made their own IIRC. Don’t recall who it was. Might do a search
Ignition switch
I’m sure you’ve already tried fiddling with shift lever
Stanley's Truck Remodel- Dove in Head First!
Might consider tappet cover gasket since your replacing gaskets
DTC P0121 Testing I dont understand could someone help/explain
Anything over 5 volts is too high?
Headlights not fitting
Looks like the grill fits closer to the fender on the left side also.
New truck-New transmission
Great. Thank you
My son joined the ranks of 2nd gen 24valve/auto owners about 2 weeks ago. He had owned a 95 12valve/5spd White dually about 10 years ago, so when he ran across this 24 valve white dually he just had to look. Ended up trading his crew cab dually 454/5spd Black Chevy for it. He took new truck to Arizona for his cousins graduation and his transmission went out. So he had to get tranny rebuilt in Arizona so he could get back home to Wyoming. I suggested he join this forum and he asked how. I couldn’t tell him. He doesn’t have a computer only a phone. Can someone here help me look smarter than I really am! Thank you in advance
You know when you're old...
I worked at a full service Texaco station. Don’t remember how much gas was or how much I made. My first vehicle that was street legal was a 64 el Camino. 283, 4 speed and posi. Engine was worn out but other than that it was pretty sweet. Sold that to my brother too.
