Royal Squire
Everything posted by Royal Squire
  1. I believe the WTS light indicates that the ECM is booting up.
  2. @TFaoro didn’t know you were still lurking around here!
  3. I always adjust them out as tight as l can then back them off
  4. Thank you for clarifying. I was visualizing someone grinding on the turbine wheel!
  5. DAP-How do you modify turbine with bench grinder?
  6. cipausa.com has some that are similar to GM but are supposed to be a bolt on. They aren’t cheap!
  7. You may be able to roll window down, block door open a few inches and tweak window frame back into shape by pushing top corner in toward body
  8. If you do a search on the site here you may find an answer as I remember this subject being addressed before.
  9. Some flatbeds are very heavy. Don’t know about yours.
  10. Go for a drive and have your wife meet you head on with her Honda to see what she thinks of new lights. That would be a real world response.
  11. Possibly they don’t want to tell us how to protect ECM as it cuts into their business
  12. Didn’t think you could burn wood in California!
  13. Might talk to @Dynamic
  14. You should be able to tell if it’s in neutral by putting transmission in gear, raising rear tires off the ground and turning drive shaft. If it’s not in neutral drive shaft won’t turn as you are trying to turn engine.
  15. From that angle it looks pretty level to me. A little hard to tell. Might be valuable to know what your intentions are, or why you want to raise rear of truck.
  16. Looks like you may have a leak also
  17. new
    Royal Squire replied to Wet Vette's topic in Introductions
    Almost a vette ?
  18. I was in Napa yesterday and they have craftsman tools now. You can buy them about anywhere except at sears
  19. I’ve never had a lift pump failure, it’s when my ECM failed and didn’t activate lift pump that I discovered mine wouldn’t run without it
  20. Mine will not run without lift pump so I suspect some of the pumps within vp are more reliable than others.
  21. Maybe get a used one from salvage yard to rebuild or use as is.
  22. When I worked at wydot we used something like this on plow trucks. You had to remove a cap and screw a hose w/fitting on that was attached to a pump and used oil tank. Worked great. No spills or drips.
